Fuel Pump Diagnostics |
solex |
Mar 21 2010, 12:40 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hi All,
Need a little help to diagnose a fuel pump problem in a 75, I do not hear the pump when I turn the key to the run position. The car was running, I had a few occasions where it would not start, let it sit for a few days and it was start right up. The grounds: under the relay board, battery and transmission have all been cleaned. All fuses are good. The relay is working as I can hear it click into position. When the key is in the run position relay terminals 30 and 85 shows 12 volts. Terminal 86 show 0.03 volts and terminal 87 show zero volts. There is no voltage at either of the fuel pump terminals. The readings at the relay is counter to to what Haynes states (86 should read 12 and 85 should be ground). I not sure where to check next, really do not want to pull the tank. Any assistance would be appreciated. Thanks, Dan |
toadman |
Apr 26 2010, 08:19 PM
Member Group: Members Posts: 168 Joined: 26-December 05 From: Cincinnati, OH Member No.: 5,316 |
Check your fuel pump. I had a similar problem with my 1976 2.0 liter with stock EFI. The car would start and run fine for anywhere from 5 minutes to an hour and then the engine would die. I spent lots of time trying to troubleshoot (relays, relay boards, grounds, etc.) with no success. I finally started the car and let it run until it stopped. I then used a couple of long wires and ran them directly from the car battery terminals to the pump terminals. The pump was dead. Turns out my pump was failing intermittently. Replaced pump and problem solved.
Lo-Fi Version | Time is now: 2nd June 2024 - 05:31 AM |
