solex |
Senior Member ![]() ![]() ![]() Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States ![]() |
Hi All,
Need a little help to diagnose a fuel pump problem in a 75, I do not hear the pump when I turn the key to the run position. The car was running, I had a few occasions where it would not start, let it sit for a few days and it was start right up. The grounds: under the relay board, battery and transmission have all been cleaned. All fuses are good. The relay is working as I can hear it click into position. When the key is in the run position relay terminals 30 and 85 shows 12 volts. Terminal 86 show 0.03 volts and terminal 87 show zero volts. There is no voltage at either of the fuel pump terminals. The readings at the relay is counter to to what Haynes states (86 should read 12 and 85 should be ground). I not sure where to check next, really do not want to pull the tank. Any assistance would be appreciated. Thanks, Dan |
solex |
I jumped pin III with the plug in the board and still not fuel pump action. I will check the ECU connector tomorrow. BTW: The wiring harness to the ECU is new from Jeff B.
Toad, the fuel pump worked when I jumped pins 30 and 87 on the fuel pump relay. I have also attached some pictures of my first relay board rebuild, but suspect (as you stated Red) that there is nothing wrong with the board I see a little oxidation but nothing broken. I will check continuity before I start in on soldering the rivets. Attached thumbnail(s) ![]() ![]() |
swl |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada ![]() |
Lo-Fi Version | Time is now: 10th June 2024 - 08:59 AM |
