| BRAVE_HELIOS |
May 2 2010, 09:12 AM
"Knowledge speaks, wisdom listens" ![]() ![]() Group: Members Posts: 295 Joined: 25-September 06 From: The Land Of ID! Member No.: 6,920 Region Association: Pacific Northwest |
Any specific camshaft/intake/carb setup recommended?
The engine is a 1993 SBC 350 out of a Pick-up. Right now, I am converting it to a carb set-up with a Elderbrock 600 CFM carb and Elderbrock Performer RPM intake. I'm also adding a set of headers. The rest of the engine will remain bone stock. There are so many different cam profiles available, I'm not sure which one to get! Once again, any help is greatly appreciated! (IMG:style_emoticons/default/biggrin.gif) |
| Mike Bellis |
May 2 2010, 10:47 AM
Resident Electrician ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,348 Joined: 22-June 09 From: Midlothian TX Member No.: 10,496 Region Association: None
There are many cam makers out there. You need to call them. Try to find a cam with a higher rpm torque curve. A roller cam will give you higher rpm capability. You can also "degree" any cam to move the hp/torque curve up or down. If you go with aluminum heads, you can up your compression ratio to take advantage of more radical high rpm cams. A single plane intake manifold will also help move your torque curve up in rpms. A dual plane manifold will lower the curve. |
BRAVE_HELIOS ?Best camshaft for SBC 350 in a 914? May 2 2010, 09:12 AM
Bruce Hinds There may be better cams since I built my engine 2... May 2 2010, 10:11 AM
BRAVE_HELIOS [quote name='Bruce Hinds' date='May 2 ... May 2 2010, 11:00 AM
messix cams are kinda like music.
i might put up with abs... May 2 2010, 10:53 AM
messix if it's a dual plane it will make a bunch on l... May 2 2010, 11:06 AM
charliew Ok, a lumpy cam sounds bad. It will make it harder... May 3 2010, 11:01 AM
BRAVE_HELIOS
Ok, a lumpy cam sounds bad. It will make it harde... May 12 2010, 09:30 PM
kg6dxn
Ok, a lumpy cam sounds bad. It will make it hard... May 12 2010, 10:24 PM
messix you wont acheive that high rmp with out changing t... May 12 2010, 09:55 PM
Bruce Hinds Each part plays a role and the intake can make a d... May 12 2010, 10:27 PM
BRAVE_HELIOS
Each part plays a role and the intake can make a ... May 13 2010, 08:02 AM
charliew Personally I wouldn't change the cam. It's... May 13 2010, 01:25 PM
jimkelly just drive that bitch and stay off the sidewalk - ... May 13 2010, 04:14 PM
PRS914-6 Why not stick with the fuel injection? You can g... May 13 2010, 04:36 PM
zymurgist If you are running stock heads, you probably have ... May 13 2010, 05:00 PM
charliew I think trucks went to roller cams with the vortec... May 14 2010, 03:40 PM![]() ![]() |
Lo-Fi Version | Time is now: 15th April 2026 - 01:41 AM |
