> Six oil change - I know I missed something...
smontanaro
post May 2 2010, 01:42 PM
Went to change the oil on my /6 today. Pulled the drain plug, removed the oil filter and let it drain for awhile. Cleaned the drain plug, installed with a new washer, installed and new oil filter and started filling.
At about the six quart mark the oil filler started to overflow. I've obviously missed something, but what?
Thx,
Skip
Ferg
post May 2 2010, 02:33 PM
You will have to break the oil line from the engine cooler, unless you have a different drain setup.
post May 2 2010, 02:48 PM
Resident German
QUOTE(Ferg @ May 2 2010, 01:33 PM) *
You need to undo one side of the line going from the bottom of the tank to the engine ...
(IMG:style_emoticons/default/shades.gif) Andy
smontanaro   Six oil change - I know I missed something...   May 2 2010, 01:42 PM
sixerdon   Did you drain the oil tank?? Don   May 2 2010, 01:46 PM
smontanaro   No, how do I do that? (We moved in the past six m...   May 2 2010, 02:15 PM
Ferg   You will have to break the oil line from the engin...   May 2 2010, 02:33 PM
SirAndy   You will have to break the oil line from the engi...   May 2 2010, 02:48 PM
TROJANMAN   Is it a stock 6, with a stock oil tank?   May 2 2010, 02:46 PM
Ferg   Start over if it were me, I'm kinda surprised ...   May 2 2010, 02:54 PM
smontanaro   Stock six, stock tank. Thanks for the assistance....   May 2 2010, 03:46 PM
ArtechnikA   There's a proper set of offset (and BIG) open-...   May 2 2010, 03:57 PM
smontanaro   I'm wondering... Do I need to drain what...   May 2 2010, 05:04 PM
ClayPerrine   Yes, start over. Pull the drain plug from the su...   May 2 2010, 05:10 PM
Phoenix 914-6GT   If you don't have these get them. They are a b...   May 2 2010, 05:23 PM
jfort   Thanks, Phoenix, for the link to the oil line wren...   May 2 2010, 06:04 PM
smontanaro   I don't understand what's so special about...   May 2 2010, 06:07 PM
ArtechnikA   I don't understand what's so special abou...   May 2 2010, 07:09 PM
Eric_Shea   Do you have proper sized open end wrenches? Mos...   May 2 2010, 08:11 PM
SLITS   Harbor freight ... air conditioning wrench set wil...   May 2 2010, 09:49 PM
Dr Evil   Clay mentioned a VERY important point. Only put in...   May 2 2010, 10:35 PM
Phoenix 914-6GT   Clay mentioned a VERY important point. Only put i...   May 2 2010, 11:05 PM
Dr Evil   The point is, if you fill it to the full mark whil...   May 2 2010, 11:09 PM
jt914-6   This is what I've done. Although not using the...   May 3 2010, 04:43 AM
- Lo-Fi Version Time is now: 2nd April 2026 - 11:54 AM
