> L-jet help needed
wanchaiwarrior
post May 2 2010, 01:48 PM
74 1.8L L-jet was running well before I decided to give the engine a good cleaning and replace all the old vacuum lines. Now it idles great, but as soon as I go beyond 1/10th throttle it just losses all power. At low throttle it will run all the way to 4,000+RPM. But beyond a certain throttle position, regardless of RPM, it just goes limp.
2 months ago I performed a full tune, including valve adjust, pertronix, plugs, rotor, cap. I have triple checked my vacuum hose connections and electrical connections. I even pulled the throttle body off and checked the TPS operation, which appears to be operating properly. Oddly, my throttle body only has one port that goes to the back side of the vacuum advance diaphragm leaving the port on the front of the vacuum advance open.
It definitely seems to be related to throttle position.
Not sure where to try next. Any suggestions would be greatly appreciated.
jsayre914
post May 2 2010, 02:08 PM
Speed Up !!!
the port should not be open to air.
check for a nipple along the goose neck rubber where it connects you should find another port open to the air. you are missing a line.
wanchaiwarrior
post May 2 2010, 02:24 PM
I prepared a detailed diagram before I started disassembly and I'm 99% sure there wasn't a vacuum line there before. I found a diagram over at Pelican that showed the extra line running from the opposite side of the throttle body. My throttle body only has one vacuum port.
messix
post May 2 2010, 03:09 PM
AKA "CLUTCH KILLER"!
From: between shit kickers and pinky lifters/ puget sound wa.north of Seattle south of Canada
QUOTE(wanchaiwarrior @ May 2 2010, 01:24 PM) *
my l=jet doesn't have anything on the advance side either. you good on that. i would check the flapper up at the air box and see if any water got under the cover.could be shorting out the wiper.
wanchaiwarrior
post May 2 2010, 03:53 PM
I actually removed the air box before cleaning, so there shouldn't be any water in there.
Now I've tried with the throttle position sensor connected and disconnected and no difference.
The car runs great under partial throttle and will rev up just fine. To me, that indicates the air box is correctly measuring air volume and delivering fuel. It is only when I add more than partial throttle that the engine literally stops firing. The second I back off the throttle it goes back to normal.
It seems like vacuum, but that would also show up at idle, and it runs absolutely smoothly at idle.
wanchaiwarrior   L-jet help needed   May 2 2010, 01:48 PM
jsayre914   the port should not be open to air. check for a n...   May 2 2010, 02:08 PM
wanchaiwarrior   I prepared a detailed diagram before I started dis...   May 2 2010, 02:24 PM
messix   I prepared a detailed diagram before I started di...   May 2 2010, 03:09 PM
wanchaiwarrior   I actually removed the air box before cleaning, so...   May 2 2010, 03:53 PM
MrKona   74 1.8L L-jet was running well before I decided t...   May 2 2010, 03:51 PM
wanchaiwarrior   Are you referring to this port? [/quote] Yes, tha...   May 2 2010, 03:57 PM
computers4kids   Did you remember to plug the harness back into the...   May 2 2010, 04:30 PM
wanchaiwarrior   Did you remember to plug the harness back into th...   May 2 2010, 04:33 PM
computers4kids   Did you remember to plug the harness back into t...   May 2 2010, 10:00 PM
wanchaiwarrior   I opened up my air flow sensor and discovered the ...   May 2 2010, 06:31 PM
Brando   To address this issue later on in Motronic cars, B...   May 3 2010, 12:26 AM
zonedoubt   More info on AFM rebuilding & diagnostics [ur...   May 5 2010, 02:34 PM
messix   thats were i thought you might have had the proble...   May 2 2010, 09:32 PM
Cap'n Krusty   74 1.8L L-jet was running well before I decided t...   May 2 2010, 10:50 PM
wanchaiwarrior   '74s have both an advance port and a retard po...   May 3 2010, 09:51 AM
zonedoubt   '74s have both an advance port and a retard p...   May 5 2010, 02:35 PM
Drums66   '74s have both an advance port and a retard ...   May 5 2010, 03:54 PM
charliew   Nice engineering change to know about. At first to...   May 3 2010, 08:34 AM
ClayPerrine   I normally agree with Cap'n Crusty, but on thi...   May 3 2010, 01:07 PM
Drums66   I'm surprised no 1 told you not to go inside t...   May 5 2010, 01:37 PM
wanchaiwarrior   I'm surprised no 1 told you not to go inside ...   May 5 2010, 02:16 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 08:31 AM
