> Master cylinder, How you know when its time..................
eyecolor
post May 3 2010, 04:31 PM
Eyecolor
I have 4 beautiful rebuilt calipers thanks to Eric and PNB . I have already used 2 quarts of fluid and the pedal is still soft.
I have been very careful to bleed in the proper order with no air being introduced.
The back calipers close nicely during the pumping and the fronts move a little.
I did note someone mentioned bleeding the proportioning valve.
I have no leaks anywhere!!
Is it time to replace the master cylinder or am I giving up too soon.
I also have an an old pedal cluster that I may owe someone as a core replacement.
Let me know if it is you or I can send it to anyone with the best advice that can use such a mess.
thanks
George
Wilmington,DE
davesprinkle
post May 3 2010, 10:33 PM
Typical symptom of a bad mc is that the pedal slowly travels to the floor. (This is with all bleeders closed.) If your pedal doesn't do this, then your MC is OK.
Try the "long tube" bleeding method. Get 15' of 1/8" ID clear vinyl tubing at your hardware store. Drop one end into the master-cylinder reservoir. (I tape the tube onto the fender to ensure that it doesn't fall out.) Put the other end on a bleeder. Open the bleeder. Sit in the car and pump the crap out of the pedal. Over and over. You'll see the bubbles chasing themselves through the loops of the tubing. Keep pumping until you don't see any more bubbles. No need for a helper and no need to waste fluid. Do this for all 8 bleeders.
BTW, you did adjust the rear venting clearance, right?
QUOTE(eyecolor @ May 3 2010, 03:31 PM) *
thanks
George
Wilmington,DE
eyecolor
post May 4 2010, 01:48 PM
Eyecolor
Thank you Dave and Zach and the all the rest
Great advice and I am certain that the lurkers (of which I used to be one) have learned something important.
I did find that I needed a 3/16 ID hose to fit .
I did not set the back clearance yet only because I seemed so close to rubbing now that I did not think it would make much of a difference before bleeding.
Let me know if I am off base and thanks again.
George
- Lo-Fi Version Time is now: 12th August 2026 - 04:38 AM
