> Projector Headlamps, Aftermarket headlamps
Frost
post Apr 18 2010, 01:13 AM
Frost
Hey guys, i was at my friends shop and i was talking to him about HID's and how i couldn't put them on my car and then he introduced me to these headlights. They have a projector, and he said i can pop the bulb out and put HID's in it. What do you guys think about these? I put a LED in the engine bay and the interior lamp in between the seats. I have the Sylvania headlamp on the left and the projector on the right.
Mikey914
post May 7 2010, 08:21 PM
The rubber man
Actually if the HID unit is set up correctly, it should be no more dangerous in a stock H4 than a projector. I have a similar (if not the same) projector lens like you have on your rig on my 951, I like it. The stock was a sealed beam and I picked up a pair on EBay for $30. The only thing with that type of lens is that it's not a true projector lens. You get refracted light out the sides of the lens that goes out in a larger cone. You can see the edges of the lens "cone" way outside the projected beam.
The issues with the HID units I have found is that some only have HID on the low beam (stay away from this) as you'll never use your high beams and if someone flashes you, you look like a chump for turning on your high beams, that seem much less bright, but now are higher.
If you get the high / low HID units, the HID slides up and down simulating the angle for the high and low beams. This is the best as it will not hit the oncoming driver with the "high" beam, that's really not as bright.
I had brought in a few of these with the idea of reselling them, but the problem was they are kind of a pain to instal, and the flickering issue. You have to allow for the wires to the ballast, and mount the ballast. I also found in my testing that over time and with moisture you will get "flickering" I have found this with 3 different manufacturers.All of them clained to be water tight, with pictures of thier units operating under water and impressive tests to suport the claims, but they all performed simularly. This is probably more a function of the moving bucket assembly in our car and the 951. The good news is that it will fault out and can be reset.
Don't get me wrong, I liked them on my 951, but they're not real easy to mount. They are pretty inexpensive, the hi / lows can me gotten in the $65 range. And they do typically run on 35w, so no need to rewire for additional wattage.
Just what I have learned. (IMG:style_emoticons/default/biggrin.gif)
Frost   Projector Headlamps   Apr 18 2010, 01:13 AM
kg6dxn   You can put HID's in your car without the proj...   Apr 18 2010, 01:58 AM
matthepcat   You can put HID's in your car without the pro...   May 7 2010, 04:05 PM
kg6dxn   You can put HID's in your car without the pr...   May 8 2010, 08:28 AM
gopack   [quote name='matthepcat' post='1315202' date='May...   May 8 2010, 12:27 PM
Mikey914   Actually if the HID unit is set up correctly, it s...   May 7 2010, 08:21 PM
toon1   I like them, Stock lights suck, anything brighter ...   May 8 2010, 09:31 AM
rekphiv   Where would one find a correct projection housing ...   May 8 2010, 07:04 PM
kg6dxn   Where would one find a correct projection housing...   May 8 2010, 08:47 PM
jetboy   That light line and shield is to limit the glare ...   May 9 2010, 10:18 PM
matthepcat   Here is Acura TL Bi-xenon projector output on my 9...   Jul 14 2010, 12:40 PM
kg6dxn   Here is Acura TL Bi-xenon projector output on my ...   Jul 14 2010, 03:58 PM
matthepcat   [quote name='matthepcat' post='1343466' date='Jul...   Jul 22 2010, 01:37 PM
kg6dxn   [quote name='matthepcat' post='1343466' date='Ju...   Jul 22 2010, 03:57 PM
matthepcat   You can get projectors of good ol e-bay. There ar...   Jul 24 2010, 06:22 PM
JmuRiz   Hey guys, i was at my friends shop and i was talk...   Jul 14 2010, 03:41 PM
jsayre914   i purchased a HID kit, with the correct lenses fro...   Jul 14 2010, 05:54 PM
Nürburg Nomad   Dislike... it looks odd and way out of place on a ...   Jul 14 2010, 06:26 PM
AndrewPokrandt   Might be interesting Headlights Andrew   Jul 14 2010, 06:47 PM
strawman   Might be interesting Headlights Andrew :sho...   Jul 15 2010, 09:19 AM
Vacca Rabite   [quote name='AndrewPokrandt' post='1343614' date=...   Jul 15 2010, 09:34 AM
turboman808   I deleted all my online pictures but I did healdig...   Jul 15 2010, 10:04 AM
BRAVE_HELIOS   I deleted all my online pictures but I did healdi...   Jul 15 2010, 08:12 PM
- Lo-Fi Version Time is now: 2nd April 2026 - 12:47 PM
