Skid |
Just a fool, a fool in love ![]() ![]() Group: Members Posts: 68 Joined: 1-February 05 From: Chattanooga, TN Member No.: 3,538 Region Association: None ![]() |
I just brought home a 73 1.7. This is the first 914 that I have actually owned, but not the first one that I have driven. My dad has always had a few 914's around and I finally decided it was time to get one of my own. When I first picked up the car, it ran pretty good and smooth. The original fuel injection has been removed and replaced with some duel single barrel weber carburetors and it has a 009 distributor. Like I said, the car ran pretty good when I first got it about 2 weeks ago. For the past 2 weeks I haven't driven the car more than just around the block, and suddenly, out of the blue, I went to go move the car and it is running bad. It has a definite misfire and, when I pull the plug wires off the distributor cap, 3 and 4 seem not to be firing. I have checked compression in those two cylinders and they are fine. I am getting fuel (I can see that the carb is squirting gas), and I have also tested to see that I was getting spark on those two cylinders. If I have spark, fuel, and compression, what am I missing? How could it just change overnight? I am pretty stumped here, my dad, who has worked on these things for over 20 years is also pretty stumped. Any ideas or help would be very appreciated.
(IMG:http://www.914world.com/bbs2/uploads_offsite/lh5.ggpht.com-3538-1273364830.1.JPG) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh4.ggpht.com-3538-1273364831.2.JPG) And the mess of an engine bay..... (IMG:style_emoticons/default/barf.gif) (IMG:http://www.914world.com/bbs2/uploads_offsite/lh6.ggpht.com-3538-1273364831.3.JPG) Thanks, Chase Birks |
McMark |
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None ![]() |
I would rebuild those carbs before I mess with anything else. I would also peek into the gas tank to check for 1/2" of rust flake on the bottom. Then I would check/replace the fuel filter. Then see how it's running.
It was running before, so it's not a compression problem. It's only affecting two cylinders, so it's not an ignition problem. It's not air. So it's a carb problem. |
Lo-Fi Version | Time is now: 11th July 2025 - 03:35 AM |
