Please help/ need advice, Rough running cold |
ILM914 |
May 9 2010, 01:34 PM
Member Group: Members Posts: 97 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hi verybody: Any help here is greatly apprecialted. My 74 2.0 studders, hesitates and runs rough 1 min after starting up for about 10 min. It runs ok when warmed up fully, but I think it would run even better warm and cold if this problem was solved. I've checked for the obvious vacume leeks - found none, and I checked the temp head sensor neat # 3 cylinder. When I connected the harness wire to negative batt terminal the car would barely run. I guess the sensor is OK?. Thank you for any help on this, everyone on this site has been really helpful - great site!. Thanks, Joe
Tom_T |
May 9 2010, 02:06 PM
TMI.... Group: Members Posts: 8,318 Joined: 19-March 09 From: Orange, CA Member No.: 10,181 Region Association: Southern California |
Check your cold start valve - that's what it usually turned out to be on my 73 2L when giving the cold running symptoms you note.
Here's a link to the part if you need it, but shop around as the price can vary: http://www.automotion.com/product.asp?pf_i...mp;dept_id=4678 |
detoxcowboy |
May 9 2010, 11:23 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Check your cold start valve - that's what it usually turned out to be on my 73 2L when giving the cold running symptoms you note. Here's a link to the part if you need it, but shop around as the price can vary: http://www.automotion.com/product.asp?pf_i...mp;dept_id=4678 The cold start valve only fires in approx freezing tempatures at farenhiet F'. actaull funtionality is dependent upon on your ts1 sensor which by parts # for years varies from 5 deg - 15 deg celcius C'.. The CHT resistance as more to do with actual communication to the ECU on engine warmth ect.. Possible to long between or since valve adjustment time.. |
Lo-Fi Version | Time is now: 8th June 2024 - 01:14 PM |
