Please help/ need advice, Rough running cold |
ILM914 |
May 9 2010, 01:34 PM
Member Group: Members Posts: 96 Joined: 3-March 09 From: NC Member No.: 10,126 Region Association: None |
Hi verybody: Any help here is greatly apprecialted. My 74 2.0 studders, hesitates and runs rough 1 min after starting up for about 10 min. It runs ok when warmed up fully, but I think it would run even better warm and cold if this problem was solved. I've checked for the obvious vacume leeks - found none, and I checked the temp head sensor neat # 3 cylinder. When I connected the harness wire to negative batt terminal the car would barely run. I guess the sensor is OK?. Thank you for any help on this, everyone on this site has been really helpful - great site!. Thanks, Joe
ericread |
May 10 2010, 09:54 AM
The Viper Blue 914 Group: Members Posts: 2,177 Joined: 7-December 07 From: Irvine, CA (The OC) Member No.: 8,432 Region Association: Southern California |
Does "cold" mean 15 degrees F outside, or just the engine has not yet been warmed up to regular operating temperature?
Eric |
detoxcowboy |
May 10 2010, 10:17 AM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Does "cold" mean 15 degrees F outside, or just the engine has not yet been warmed up to regular operating temperature? Eric cold for the engine means ambient tempature( in so. cal. that means about 70 degress in the afternoon), cold for the cold start valve means near freezing ambient tempatures (montana winter ect..)... |
Lo-Fi Version | Time is now: 1st June 2024 - 01:55 PM |
