> Tie Rod Ball Joint Question
kenshapiro2002
post May 11 2010, 12:09 PM
The bellows on my left side tie rod end ball joint is shot (obviously). I'm assuming the downside is loss of grease...ingestion of dirt, and premature wear? Anyway, what's the fix? Do I need to replace the whole joint or can the bellows be replaced. Hand tools? Ease of repair on a scale of 1-10 with 1 being changing a tire and 10 being rebuilding the trans.?
dr914@autoatlanta.com
post May 11 2010, 12:11 PM
replace the end. They are cheap enough and chances are that if the boot is cracked, the tie rod end is worn.
kenshapiro2002   Tie Rod Ball Joint Question   May 11 2010, 12:09 PM
dr914@autoatlanta.com   replace the end. They are cheap enough and chances...   May 11 2010, 12:11 PM
kenshapiro2002   George, Thanks. BTW, the inquiry is not an order....   May 11 2010, 12:13 PM
SirAndy   replace the end. They are cheap enough and chance...   May 11 2010, 12:13 PM
6freak   PB BLASTER IS YOUR FRIEND ..let soak for a day the...   May 11 2010, 03:22 PM
kenshapiro2002   PB Blaster (never heard of it) any better than CRC...   May 11 2010, 04:09 PM
r_towle   Its actually a fairly easy project. Jack it up and...   May 11 2010, 05:18 PM
kenshapiro2002   Thanks. Not really sure where you're telling m...   May 11 2010, 05:26 PM
kenshapiro2002   Rick, There was no nut on the threaded rod of the...   May 17 2010, 11:12 AM
underthetire   PB blaster Aero Kroil-better in my book or for the...   May 11 2010, 05:23 PM
r_towle   Simple way is to have sears replace the end for yo...   May 11 2010, 05:33 PM
kenshapiro2002   That's no fun at all, and doesn't increase...   May 11 2010, 05:35 PM
kenshapiro2002   Speaking of alignment...the car drifts to the righ...   May 13 2010, 04:30 PM
jaxdream   Ken The removal is fairly easy , look at it . The ...   May 11 2010, 05:51 PM
jaxdream   RE: Tie Rod Ball Joint Question   May 11 2010, 05:53 PM
Cap'n Krusty   If you beat on the threaded end, you'll likely...   May 11 2010, 05:59 PM
kenshapiro2002   Thanks guys...as always.   May 11 2010, 06:04 PM
tat2dphreak   easy. I did the shocks the ball joints, bearings,...   May 13 2010, 06:08 PM
- Lo-Fi Version Time is now: 24th August 2026 - 02:47 AM
