| kenshapiro2002 |
May 11 2010, 12:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
The bellows on my left side tie rod end ball joint is shot (obviously). I'm assuming the downside is loss of grease...ingestion of dirt, and premature wear? Anyway, what's the fix? Do I need to replace the whole joint or can the bellows be replaced. Hand tools? Ease of repair on a scale of 1-10 with 1 being changing a tire and 10 being rebuilding the trans.?
| r_towle |
May 11 2010, 05:18 PM
Custom Member ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 24,705 Joined: 9-January 03 From: Taxachusetts Member No.: 124 Region Association: North East States
Its actually a fairly easy project.
Jack it up and turn the wheel so that end is sticking out of the wheel well as far as you can get it. remove the nut. Get a 5 lb hammer or a large ball peen hammer. If you look at the spindle where the tie rod end goes in, on one side is the arm that attaches to the rest of the spindle... Hit the arm directly opposite of the arm. Its designed for this (all joints are) and it you hit it firmly and square, a few wacks and the joint comes loose. Now, once its out, measure the exact distance from the end of the tube it threads into out to the end of the tie rod, or a place you can measure accurately. Write that down. Loosen the lock nut (hold the middle tube at the notch with a cresent wrench, use another wrench on the nut. then turn out the threaded tie rod end. I cant remember, but each side is threaded either left or right handed. Before you strip the nut, try it the other direction. Put the nut on the new tie rod end and thread it in to the same dimension that you measured above. Put it back in the spindle and tighen everything up. Make sure to tighten the lock nut tight. If you think you messed up on the measurement, bring it to sears and have them give you an alignment. Rich |
kenshapiro2002 Tie Rod Ball Joint Question May 11 2010, 12:09 PM
dr914@autoatlanta.com replace the end. They are cheap enough and chances... May 11 2010, 12:11 PM
kenshapiro2002 George,
Thanks. BTW, the inquiry is not an order.... May 11 2010, 12:13 PM
replace the end. They are cheap enough and chance... May 11 2010, 12:13 PM
6freak PB BLASTER IS YOUR FRIEND ..let soak for a day the... May 11 2010, 03:22 PM
kenshapiro2002 PB Blaster (never heard of it) any better than CRC... May 11 2010, 04:09 PM
kenshapiro2002 Thanks. Not really sure where you're telling m... May 11 2010, 05:26 PM
kenshapiro2002 Rick,
There was no nut on the threaded rod of the... May 17 2010, 11:12 AM
underthetire PB blaster
Aero Kroil-better in my book
or for the... May 11 2010, 05:23 PM
r_towle Simple way is to have sears replace the end for yo... May 11 2010, 05:33 PM
kenshapiro2002 That's no fun at all, and doesn't increase... May 11 2010, 05:35 PM
kenshapiro2002 Speaking of alignment...the car drifts to the righ... May 13 2010, 04:30 PM
jaxdream Ken
The removal is fairly easy , look at it . The ... May 11 2010, 05:51 PM
jaxdream RE: Tie Rod Ball Joint Question May 11 2010, 05:53 PM
Cap'n Krusty If you beat on the threaded end, you'll likely... May 11 2010, 05:59 PM
kenshapiro2002 Thanks guys...as always. May 11 2010, 06:04 PM
tat2dphreak
easy. I did the shocks the ball joints, bearings,... May 13 2010, 06:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th August 2026 - 03:40 AM |
