| kenshapiro2002 |
May 11 2010, 12:09 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
The bellows on my left side tie rod end ball joint is shot (obviously). I'm assuming the downside is loss of grease...ingestion of dirt, and premature wear? Anyway, what's the fix? Do I need to replace the whole joint or can the bellows be replaced. Hand tools? Ease of repair on a scale of 1-10 with 1 being changing a tire and 10 being rebuilding the trans.?
| Cap'n Krusty |
May 11 2010, 05:59 PM
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California |
If you beat on the threaded end, you'll likely never get it loose. The ball joint is a tapered fit into the arm on the spindle. You have to literally shock it loose unless you have the correct removal tool. "Pickle forks" don't really work all that well, and penetrating oil won't affect it as it's a press fit. We use a large ball peen hammer. Be sure you hit the "ring" at a right angle and really hard. Usually they come loose in 2-3 whacks, but sometimes they let go on the first attempt. If you don't even have to hit it, the nut was never tightened properly. When you install the new one, you may have to apply vertical pressure on the top of the tie rod end to get the stud to stop turning. Air tools are your friend in this case.
The Cap'n |
kenshapiro2002 Tie Rod Ball Joint Question May 11 2010, 12:09 PM
dr914@autoatlanta.com replace the end. They are cheap enough and chances... May 11 2010, 12:11 PM
kenshapiro2002 George,
Thanks. BTW, the inquiry is not an order.... May 11 2010, 12:13 PM
replace the end. They are cheap enough and chance... May 11 2010, 12:13 PM
6freak PB BLASTER IS YOUR FRIEND ..let soak for a day the... May 11 2010, 03:22 PM
kenshapiro2002 PB Blaster (never heard of it) any better than CRC... May 11 2010, 04:09 PM
r_towle Its actually a fairly easy project.
Jack it up and... May 11 2010, 05:18 PM
kenshapiro2002 Thanks. Not really sure where you're telling m... May 11 2010, 05:26 PM
kenshapiro2002 Rick,
There was no nut on the threaded rod of the... May 17 2010, 11:12 AM
underthetire PB blaster
Aero Kroil-better in my book
or for the... May 11 2010, 05:23 PM
r_towle Simple way is to have sears replace the end for yo... May 11 2010, 05:33 PM
kenshapiro2002 That's no fun at all, and doesn't increase... May 11 2010, 05:35 PM
kenshapiro2002 Speaking of alignment...the car drifts to the righ... May 13 2010, 04:30 PM
jaxdream Ken
The removal is fairly easy , look at it . The ... May 11 2010, 05:51 PM
jaxdream RE: Tie Rod Ball Joint Question May 11 2010, 05:53 PM
kenshapiro2002 Thanks guys...as always. May 11 2010, 06:04 PM
tat2dphreak
easy. I did the shocks the ball joints, bearings,... May 13 2010, 06:08 PM![]() ![]() |
Lo-Fi Version | Time is now: 24th August 2026 - 02:47 AM |
