Larouex |
Larouex ![]() ![]() Group: Members Posts: 144 Joined: 22-July 08 From: Larouex@gmail.com Member No.: 9,339 Region Association: Pacific Northwest ![]() |
Hello,
I wanted to document my SDS install as I am doing a few custom steps I haven't seen anyone post yet. I ordered the EFI system with the 02 System (which requires welding in the bung and sensor, more on that later). I already have the Crane Xr700 and the Crane Coil, so my ignition is solid and works well and decided to skip the ignition and crankfire for now. My first goal was to fit the SDS ECU into the existing 914 DJet ECU as I had a couple extra boxes. I am pleased with the results, although I have to mount the O2 sensor and tach boost box, so far I am not sure how I want those items to no be conspicuous in the engine bay. I will post more as I get the install further along, but here are the pics of the box install and fitment... Full image set @ Flickr 914 SDS into ECU Photo Set (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.static.flickr.com-9339-1273641496.1.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.static.flickr.com-9339-1273641496.2.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.static.flickr.com-9339-1273641496.3.jpg) (IMG:http://www.914world.com/bbs2/uploads_offsite/farm2.static.flickr.com-9339-1273641496.4.jpg) |
Jake Raby |
Engine Surgeon ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,394 Joined: 31-August 03 From: Lost Member No.: 1,095 Region Association: South East States ![]() |
Be careful when sealing the SDS in a container.. I have had issues with that in the past as the ECU ran at a temperature that was elevated. I've always surface mounted the ECUs since that occurrence with no issues.
Larouex |
Be careful when sealing the SDS in a container.. I have had issues with that in the past as the ECU ran at a temperature that was elevated. I've always surface mounted the ECUs since that occurrence with no issues. Hmm, good information and you would know! In your opinion, the SDS ECU needs air flow for cooling of the internals? |
Lo-Fi Version | Time is now: 18th June 2024 - 01:55 AM |
