> Generators and power requirements
Rand
post May 13 2010, 08:19 AM
Cross Member
Want to run power tools and a light-duty welder - just a 110-powered flux-core. I know there's math to calculate power requirements, but there are also variables about how long you can run it continuously and all that. So I thought I'd see if those with experience would chime in.
I don't need heavy duty. But I don't want to be worried about when I have to stop and let things cool down.
Just for argument's sake, let's use Harbor Freight as an example... Say you have this 90-amp welder:
http://www.harborfreight.com/90-amp-flux-w...lder-98871.html
Out of these generators, which could and could not handle it?
http://www.harborfreight.com/engines-gener...generators.html
underthetire
post May 13 2010, 09:19 AM
I can tell you first hand that the 90 amp HF flux welder will kill a 15 amp breaker if used on high.
If your running power tools, resistive load is calculated a little different. It has a longer start up cycle then lets say a tv. I would stay in the 3500-4500 watt range myself.
watts / volts =amps.
- Lo-Fi Version Time is now: 4th March 2026 - 01:43 PM
