> Fuel Hose, Will 5/16 work
914fun
post May 13 2010, 07:44 PM
Im needing new Fuel hose inside the engine bay. Mostly the line to the fuel rails. Will 5/16 work on everything in there. I see it is all 3/8 right now but it seems to fit loose. Thanks
markb
post May 13 2010, 10:00 PM
914less :(
GPR is German Parts and Restoration. (IMG:style_emoticons/default/bye1.gif)
914fun
post May 13 2010, 10:05 PM
QUOTE(markb @ May 13 2010, 11:00 PM) *
Cool, Thanks
realred914
post May 14 2010, 07:51 AM
Group: Retired Members
QUOTE(914fun @ May 13 2010, 09:05 PM) *
Cool, Thanks
actually 5/16 inch works fine on our rides. you may want to specifcy the new hoses that is now introduced for the oxygenated and alchohol fuels mandated in many areas. these new fuels will harm most standrd fuel hoses (and other rubber bits) becuase of this a new type of hoses has been introducedsome years ago. It is the latest standrd for fuel injection motors (and is the only lawfull replacemnet hose to keep emmission legal on new cars)
the new hose has a teflon like liner inside, that resists the new fuels. the hoses with the liner has an SAE rating of 30R9 (the old non-lined hoses is 30R7) the new hose will resist the corrosive effects of the new fuels and helps fight smog becuase it is over 30 times less permiable to gas fumes that teh old SAE30R7 hoses.
as pointed out, you need to run the correct solid band hose clamps, no perferated clamsp as teh rubber can squeeze thru teh holes over time hence losseening the clamp
i have used the 5/16 inch hose for over a decade with no failure with hose clamps.
I have been unable to find the lined hose in metric but teh 5/16 inch works great. and will out last the standard hose. the linner will not dry out and get brittle and will prevent the rubber outside from getting in contact with the fuel, thus giving the hose a much much longer life, even with todays horrible fuel mixes.
- Lo-Fi Version Time is now: 23rd November 2026 - 12:41 AM
