> E Brake, Wires / Route
EdwardBlume
post May 16 2010, 05:53 PM
I'm reinstalling the ebrake switch on the '74. How many wires? One? And does it route from around back, forward under the lever, and through the circle, or somewhere else?
McMark
post May 16 2010, 08:12 PM
914 Freak!
Factory routing is to exit the center tunnel in the same location as the backpad light wires and the seat belt wires, then run behind the drivers seat, behind the rubber sound pad (which holds it up off the floor) and then to the left of the seat. There is a small round grommet that cushions the entrance into the seat cross member, and then it plugs into the switch. Make sure the screw that affixes the switch makes a good ground. Most of the time it's fine, so don't do anything special to make it ground. But do check it with a multimeter once it's installed, just to be sure.
- Lo-Fi Version Time is now: 16th June 2024 - 09:01 PM
