KaptKaos |
Family ![]() ![]() ![]() ![]() Group: Members Posts: 4,009 Joined: 23-April 03 From: Near Wausau Member No.: 607 Region Association: Upper MidWest ![]() |
Haynes says 23 lb and give a tightening diagram.
That 23 lbs included the old head gaskets, which I am not using. Does the torque setting need to be tighter without head gaskets? If so, what? TIA |
KaptKaos |
It's my understanding that VW even changed their spec and removed the head gaskets from their rebuilds.
The cylinders were lapped into the heads. I've heard that Jake uses spray on copper gasket material in the combustion chamber. Supposedly, this creates a good seal for the cylinders to the heads and the excess just burns off. I haven't done that but now that I need to re-torque the heads I might. Any other hints or tips? |
detoxcowboy |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa ![]() |
It's my understanding that VW even changed their spec and removed the head gaskets from their rebuilds. The cylinders were lapped into the heads. I've heard that Jake uses spray on copper gasket material in the combustion chamber. Supposedly, this creates a good seal for the cylinders to the heads and the excess just burns off. I haven't done that but now that I need to re-torque the heads I might. Any other hints or tips? "It's my understanding that VW even changed their spec and removed the head gaskets from their rebuilds. I have read the same.. I can't confirm nor denie what Jake is doing, but also thought I read he does not use head gaskets either.. after issue with them ect.. |
Lo-Fi Version | Time is now: 18th September 2025 - 08:09 PM |
