VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,752 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
My 2056 is getting elevated oil temps on the freeway. I am using a high volume pump, and seeing about 40 pounds of pressure on the freeway when my oil is up to temp.
What I think is happening is that there is too much pressure, and the oil is not being pumped through the oil cooler due to the check valve closing the passage. However, this is just a guess, as I don't have any way to test it. All I know is that when I am driving at revs, oil temp goes up and if I keep driving at higher revs the oil temps stay up). if I drop revs, oil temps fall back into place, but I can't do that on the freeway without building a lot of head heat. Before I go through the trouble and expense of adding an oil cooler, I want to make sure that I have checked out the simple fixes first. What do I do to make sure oil if going through the oil cooler? What is the point where pressure cuts off passage through the cooler? All tin is in place, and fan housing flaps divert air over the oil cooler 100% of the time (no thermostat in place, so the flaps are always set to cool). Zach |
realred914 |
Senior Member ![]() ![]() ![]() Group: Retired Members Posts: 1,086 Joined: 1-April 10 From: california Member No.: 11,541 Region Association: None ![]() |
these cars ran hot even stock (hence the factory adding the air flaps under the car, and the shrinking of the red zone on the oil temp gage.. Youhave a larger motor so even more heat is expected.
the 40 psi on freeway is not too high a pressure, any less and I'd be worried. you may need an extra cooler. I would certainly run a thrmostate bellows. it is poor economy to not get one, you will have much faster engine wear with no warm up ability. would you be fine running your chevy ford or honda with the thermostat removed???? come on now and get that thing in there to assure longer engine life as far as the high temps, you might also want to check head temps to see what mihgt be out of control. leaves and crap can block the oil cooler, check that my stock 2.0 also runs hot on warm days on long freeway drives. have to back opff else temp keeps going up (and pressure donw!) I have all tin in place and sealed, every thing right to optimize the stock system, yet it still runs hot, i even retarded the timing a few degrees, no change! I will be adding one oil cooler to my car becuase of this, until then I drive easy when it is hot and pay close attention to my gages and slow donw if too hot. |
70_914 |
Member ![]() ![]() Group: Members Posts: 395 Joined: 4-December 09 From: Roy, WA Member No.: 11,096 Region Association: Pacific Northwest ![]() |
I would certainly run a thrmostate bellows. it is poor economy to not get one, you will have much faster engine wear with no warm up ability. would you be fine running your chevy ford or honda with the thermostat removed???? come on now and get that thing in there to assure longer engine life I have a pile of these laying around now, let me know if you need one. I heard they are hard to find, but I don't have that problem... I go and look on my work bench and find 4 of them (IMG:style_emoticons/default/biggrin.gif) Like everything I have sold it would be cheap. |
Lo-Fi Version | Time is now: 2nd July 2025 - 11:59 PM |
