> too much oil pressure?, high OT on the freeway
VaccaRabite
post May 17 2010, 08:57 AM
En Garde!
My 2056 is getting elevated oil temps on the freeway. I am using a high volume pump, and seeing about 40 pounds of pressure on the freeway when my oil is up to temp.
What I think is happening is that there is too much pressure, and the oil is not being pumped through the oil cooler due to the check valve closing the passage. However, this is just a guess, as I don't have any way to test it. All I know is that when I am driving at revs, oil temp goes up and if I keep driving at higher revs the oil temps stay up). if I drop revs, oil temps fall back into place, but I can't do that on the freeway without building a lot of head heat.
Before I go through the trouble and expense of adding an oil cooler, I want to make sure that I have checked out the simple fixes first.
What do I do to make sure oil if going through the oil cooler? What is the point where pressure cuts off passage through the cooler?
All tin is in place, and fan housing flaps divert air over the oil cooler 100% of the time (no thermostat in place, so the flaps are always set to cool).
Zach
yeahmag
post May 17 2010, 11:43 AM
I haven't gotten a solid answer on this, but I don't think you can run the thermostat with a header.
Vacca Rabite   too much oil pressure?   May 17 2010, 08:57 AM
r_towle   Interesting issue. I dont know the pressure cut o...   May 17 2010, 09:00 AM
Vacca Rabite   Yep, the little flaps are in place. And I should m...   May 17 2010, 09:03 AM
r_towle   I have always seen high oil temps at 65 mph up to ...   May 17 2010, 09:06 AM
Vacca Rabite   We used a simple sandwich adapter and a 2*10 inch...   May 17 2010, 09:11 AM
mightyohm   We used a simple sandwich adapter and a 2*10 inch...   May 17 2010, 11:37 AM
underthetire   I get 40 PSI at 210 deg on the Fwy as well. Fought...   May 17 2010, 09:13 AM
Vacca Rabite   Heater flappers and loose tin. Mine did a huge dr...   May 17 2010, 09:19 AM
Spoke   I could try blocking the vents at the bottom of t...   May 17 2010, 02:06 PM
jhadler   I forgot who originally mentioned the cavitation i...   May 17 2010, 02:32 PM
Lennies914   Zach, I had this exact discussion with BDStone at ...   May 17 2010, 09:14 AM
r_towle   I recall that either aircooled.net, cbperformance,...   May 17 2010, 09:18 AM
Vacca Rabite   My timing right now is at 28.5* Checked it two we...   May 17 2010, 09:22 AM
realred914   these cars ran hot even stock (hence the factory a...   May 17 2010, 09:47 AM
70_914   I would certainly run a thrmostate bellows. it ...   May 17 2010, 11:30 AM
Vacca Rabite   I would certainly run a thrmostate bellows. it...   May 17 2010, 11:42 AM
Vacca Rabite   Thanks RealRed. I have a Dakota Digital Head Temp...   May 17 2010, 09:55 AM
yeahmag   Got an O2 on the car? If not might want to get one...   May 17 2010, 10:29 AM
detoxcowboy   "I recall that either aircooled.net, cbperfor...   May 17 2010, 10:36 AM
Jake Raby   40 PSI is perfect on the highway, its not high eno...   May 17 2010, 11:24 AM
Vacca Rabite   40 PSI is perfect on the highway, its not high en...   May 17 2010, 11:36 AM
yeahmag   I haven't gotten a solid answer on this, but I...   May 17 2010, 11:43 AM
HAM Inc   You need to keep in mind that all of the oil does ...   May 17 2010, 11:54 AM
Vacca Rabite   You need to keep in mind that all of the oil does...   May 17 2010, 12:14 PM
jhadler   ...Tight piston clearances will cause high oil te...   May 17 2010, 12:53 PM
tradisrad   I'm curious how high oil pressure makes the oi...   May 17 2010, 11:57 AM
DanT   When I built my 2056 I did away with the thermosta...   May 17 2010, 12:20 PM
realred914   When I built my 2056 I did away with the thermost...   May 18 2010, 09:30 AM
HAM Inc   Zach the pressure bypass drops the pressure in the...   May 17 2010, 12:31 PM
Vacca Rabite   Okay. Bear with me, as I am just thinking through...   May 17 2010, 12:39 PM
mightyohm   What oil temps are you actually seeing?   May 17 2010, 12:52 PM
Vacca Rabite   What oil temps are you actually seeing? 235-245 ...   May 17 2010, 12:54 PM
Spoke   I thought cavitation was in respect to closing off...   May 17 2010, 03:00 PM
underthetire   Wouldn't blocking them off be the same as if y...   May 17 2010, 03:45 PM
HAM Inc   The stiffer the spring the higher the oil pressur...   May 17 2010, 04:37 PM
Vacca Rabite   [quote name='HAM Inc' date='May 17 201...   May 17 2010, 07:55 PM
AndrewP   Do you know if your oil temp gauge is accurate? A...   May 17 2010, 05:32 PM
r_towle   Do you think your header might be adding heat to t...   May 17 2010, 06:47 PM
r_towle   I had a decent idea for your header leak issue. C...   May 17 2010, 08:14 PM
HAM Inc   Zach that is propbably in the 10lbs/1000rpm...   May 18 2010, 07:53 AM
Vacca Rabite   What is the history of your O.E. cooler? Came w...   May 18 2010, 08:09 AM
r_towle   What is the history of your O.E. cooler? Came ...   May 18 2010, 05:42 PM
Racer Chris   I drive like a bat out of hell, pretty much all th...   May 18 2010, 11:06 AM
yeahmag   Damn... So what's your secret?   May 18 2010, 11:08 AM
Borderline   Zach, I haven't had the opportunity to verify ...   May 18 2010, 11:23 AM
Elliot Cannon   Start your car and put your hand down by the vents...   May 18 2010, 12:25 PM
realred914   Start your car and put your hand down by the vent...   May 18 2010, 01:53 PM
Cevan   Start your car and put your hand down by the ven...   May 18 2010, 02:27 PM
Elliot Cannon   I got rid of the Home Depot scoop :barf: and made...   May 18 2010, 12:27 PM
Cap'n Krusty   Having seen the devastating effects of CV bolt fai...   May 18 2010, 01:37 PM
Elliot Cannon   Having seen the devastating effects of CV bolt fa...   May 18 2010, 01:53 PM
markb   however if I heard the noise of a broken cv and a...   May 18 2010, 02:59 PM
Bleyseng   yeah, it will be fine.   May 18 2010, 02:32 PM
yeahmag   I think too retarded makes heat too... At least th...   May 18 2010, 05:44 PM
70_914   Too much oil pressure could cause excess heat beca...   May 18 2010, 07:03 PM
Chris Hamilton   Too much oil pressure could cause excess heat bec...   May 18 2010, 07:40 PM
70_914   Too much oil pressure could cause excess heat be...   May 18 2010, 11:24 PM
realred914   Too much oil pressure could cause excess heat bec...   May 19 2010, 08:26 AM
70_914   Too much oil pressure could cause excess heat be...   May 19 2010, 08:30 AM
Jake Raby   Thats my least favorite exhaust... For many reason...   May 18 2010, 07:19 PM
70_914   Here is some information: http://www.machinerylubr...   May 18 2010, 11:33 PM
Chris Hamilton   Could you point out what part of your links apply ...   May 19 2010, 01:00 AM
70_914   Sorry to hijack the thread discussing basic thermo...   May 19 2010, 08:24 AM
70_914   GO VIKINGS! WWU is in Bellingham and has an o...   May 19 2010, 08:31 AM
realred914   Sorry to hijack the thread discussing basic therm...   May 19 2010, 08:35 AM
Chris Hamilton   If you wanted Example A to apply to this situation...   May 19 2010, 12:46 PM
Racer Chris   but the bottom line is that oil pressure is not ...   May 19 2010, 04:12 PM
70_914   but the bottom line is that oil pressure is not...   May 19 2010, 04:47 PM
Racer Chris   Higher pressure from a high volume pump isn't ...   May 19 2010, 04:10 PM
Vacca Rabite   So, coming back down from high science to backyard...   May 20 2010, 09:02 AM
jhadler   So, coming back down from high science to backyar...   May 20 2010, 09:29 AM
type11969   Spin on type, drops the filter about an inch, no c...   May 20 2010, 10:04 AM
realred914   Spin on type, drops the filter about an inch, no ...   May 20 2010, 10:08 AM
sean_v8_914   did you check, make sure your fan did not eat some...   May 20 2010, 10:22 AM
yeahmag   I had that happen on my 2276 Type I once... Good p...   May 20 2010, 10:26 AM
realred914   hence you put on a fan screen taken from a late mo...   May 20 2010, 10:40 AM
- Lo-Fi Version Time is now: 3rd July 2025 - 12:15 AM
