> I.D. My Ball Joint Please?
kenshapiro2002
post May 17 2010, 01:37 PM
The car is a 1970 914 that was converted to 5 lug using late 80s/early90s 911 front end parts. Not sure if the A arms were changed over and whether the ball joints I need are 914 or 911 parts (think they're 914, but not sure). Can I get these ball joints out using non-impact, hand tools, or should I just pay a local Porsche wrench to do it? Also, I thought the retainer nut on the bottom of the joint was supposed to be facing the front. Mine is the opposite. Does it matter?
kenshapiro2002   I.D. My Ball Joint Please?   May 17 2010, 01:37 PM
Cap'n Krusty   914 and 911 ball joints are the SAME. These appea...   May 17 2010, 01:52 PM
kenshapiro2002   The joint itself seems to be OK, and the car only ...   May 17 2010, 02:22 PM
kenshapiro2002   Cap'n...damn...you're wrong again! The...   May 20 2010, 09:06 AM
kenshapiro2002   BTW...that number is on the bellows, not the joint...   May 20 2010, 09:10 AM
r_towle   you dont replace the boot, you replace the whole b...   May 17 2010, 07:43 PM
kenshapiro2002   They are not cheap, but I'll do as you say sir...   May 17 2010, 08:11 PM
kenshapiro2002   Once I had her "airborne"...changing out...   May 18 2010, 10:52 AM
kenshapiro2002   Just noticed that PP says the tool is just for ins...   May 18 2010, 10:55 AM
kenshapiro2002   Here tis. You can see how the slot on the joint is...   May 20 2010, 09:21 AM
detoxcowboy   Lemfroeder Ball Joints and new Pins, You can get b...   May 20 2010, 09:32 AM
Cap'n Krusty   Look at the first picture. Does that look like a ...   May 20 2010, 09:57 AM
kenshapiro2002   Owe you an apology...haven't gotten the right ...   May 20 2010, 10:10 AM
kenshapiro2002   Sure 'nuff...got an early style strut on the l...   May 20 2010, 11:21 AM
kenshapiro2002   Here are the final shots. Correct me if I'm wr...   May 20 2010, 12:41 PM
kenshapiro2002   Here are some better shots of my left side (old st...   May 25 2010, 08:56 AM
kenshapiro2002   Here are some better shots of my left side (old st...   May 25 2010, 08:57 AM
kenshapiro2002   RE: I.D. My Ball Joint Please?   May 25 2010, 09:02 AM
kenshapiro2002   Wow...sorry...site's acting weird...posting tw...   May 25 2010, 09:21 AM
Cap'n Krusty   That's damage from the shaft of the ball joint...   May 25 2010, 09:26 AM
Dr Evil   Its obvious that the guy had no idea what he was d...   May 25 2010, 09:54 AM
kenshapiro2002   Now I'm really confused...I thought the strut ...   May 25 2010, 10:00 AM
kenshapiro2002   On my right side...with the tapered pin and no spl...   May 25 2010, 10:24 AM
Dr Evil   I was referring to the ball joints and fasteners b...   May 25 2010, 10:50 AM
kenshapiro2002   So...my strut on the right side...the one that had...   May 25 2010, 11:22 AM
kenshapiro2002   OK...doing the right side now...no split in the st...   May 29 2010, 11:13 AM
jaxdream   I believe Dr. evil was refering to the balljoint i...   May 25 2010, 12:15 PM
kenshapiro2002   Makes sense. Still wondering why my right side...n...   May 25 2010, 12:32 PM
Dr Evil   The new style strut housing had the wrong fastener...   May 25 2010, 04:19 PM
kenshapiro2002   Alright...tried to call you but you were gone...ho...   May 25 2010, 04:39 PM
kenshapiro2002   RE: I.D. My Ball Joint Please?   May 25 2010, 05:07 PM
jaxdream   Yes that is probably your solution but do check th...   May 25 2010, 08:22 PM
kenshapiro2002   Thanks again...a new strut will eventually be happ...   May 26 2010, 04:57 AM
Dr Evil   It looks like my recollection of hole size in the ...   May 29 2010, 02:47 PM
kenshapiro2002   Cool...back out to finish up the job. I've wai...   May 29 2010, 02:59 PM
kenshapiro2002   OK...got the ball joint installed on the right sid...   May 29 2010, 04:58 PM
kenshapiro2002   Guess I should have waited until somebody responde...   May 31 2010, 12:43 PM
Cap'n Krusty   Maybe I've been too subtle in my comments. BU...   May 31 2010, 12:47 PM
kenshapiro2002   Gotcha, but what did I do? Does the shock bottom o...   May 31 2010, 12:53 PM
Cap'n Krusty   Get the part number off the other side. It'll...   May 31 2010, 01:18 PM
kenshapiro2002   My right side is 911-341-080-04 What's ...   May 31 2010, 03:03 PM
kenshapiro2002   Cap'n. As always, much easier than I'd ima...   Jun 1 2010, 08:49 AM
- Lo-Fi Version Time is now: 7th December 2025 - 10:37 AM
