| bradtho |
May 16 2010, 09:35 PM
Member ![]() ![]() Group: Members Posts: 266 Joined: 22-December 09 From: Seattle, WA Member No.: 11,165 Region Association: None |
Using a drill I figured out that the speedo cable was broken, so I bought another and broke it testing it with my drill. I cut one of the tips off and pulled the speedometer completely out. Using the tip and a vise grip, I am unable to turn the speedo at all. I followed the instructions on PP to disassemble the speedo and can actually spin the magnet wheel, but it will not spin the square drive for the cable when the magnet spins.
btw: the needle moves quite freely, and the speed unit is completely disconnected from the odo so it can't be the odometer gears. Reading other threads it sounds like taking this apart any further isn't advised. Anyone had this problem before or have a suggestion besides sending it somewhere for repair? |
| underthetire |
May 17 2010, 08:30 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,062 Joined: 7-October 08 From: Brentwood Member No.: 9,623 Region Association: Northern California |
A 25.00 speedo is a lot cheaper than two 38.00 cables. Why fight it. (IMG:style_emoticons/default/confused24.gif)
bradtho speedometer won't turn May 16 2010, 09:35 PM
McMark Buy a different one. They're not expensive. ... May 17 2010, 12:33 PM
Buy a different one. They're not expensive. ... May 17 2010, 01:08 PM
messix look in the classifieds, rich has a parts posting ... May 17 2010, 01:19 PM
markb I'd sell you a used (untested) one for $2... May 17 2010, 01:19 PM
Bartlett 914
Using a drill I figured out that the speedo cable... May 17 2010, 01:29 PM
charliew It's not rocket science. Put the cable or a sm... May 17 2010, 07:39 PM
bradtho
It's not rocket science. Put the cable or a s... May 17 2010, 08:25 PM
charliew If you have broken the grip of the magnet to the s... May 18 2010, 12:57 PM![]() ![]() |
Lo-Fi Version | Time is now: 8th December 2025 - 10:32 PM |
