VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,752 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
My 2056 is getting elevated oil temps on the freeway. I am using a high volume pump, and seeing about 40 pounds of pressure on the freeway when my oil is up to temp.
What I think is happening is that there is too much pressure, and the oil is not being pumped through the oil cooler due to the check valve closing the passage. However, this is just a guess, as I don't have any way to test it. All I know is that when I am driving at revs, oil temp goes up and if I keep driving at higher revs the oil temps stay up). if I drop revs, oil temps fall back into place, but I can't do that on the freeway without building a lot of head heat. Before I go through the trouble and expense of adding an oil cooler, I want to make sure that I have checked out the simple fixes first. What do I do to make sure oil if going through the oil cooler? What is the point where pressure cuts off passage through the cooler? All tin is in place, and fan housing flaps divert air over the oil cooler 100% of the time (no thermostat in place, so the flaps are always set to cool). Zach |
HAM Inc |
Senior Member ![]() ![]() ![]() Group: Members Posts: 850 Joined: 24-July 06 From: Watkinsville,GA Member No.: 6,499 Region Association: None ![]() |
QUOTE 35 psi when it gets hot cruising on the highway. I have only let it get there twice though. By the time the oil gets that thin I am looking for an exit. At idle it will be about 10psi. Zach that is propbably in the 10lbs/1000rpm's range. You sure don't want a softer bypass spring. I would be inclined to leave that alone and look elsewhere for your heating issue. What is the history of your O.E. cooler? |
VaccaRabite |
What is the history of your O.E. cooler? Came with the motor. I flushed the inside with oil and made sure the outside had no obstructions that would block air passage when I rebuilt the motor. I did not have it ultrasonicly cleaned. I am using a EuroRace header, and the drivers side pipes do pass right under the oil pan, so that can't be helpful. So, right now, these are the actions I am going to take: 1) Cap the stubby vents that are supposed to go to the heaters that currently just vent to open air, and see if that puts more air into the tins. 2) Try to add a little more advance to the timing (go from 28* to 30* and see what happens). 3) add a little header wrap or header blanket to the pipes that cross under the engine case. Do the experts here see any issues with this plan? Zach |
Lo-Fi Version | Time is now: 3rd July 2025 - 12:11 AM |
