> My personalized hell hole, Need advice on the best fix...
saigon71
post May 19 2010, 06:38 AM
Disclaimer: It is clear from these pictures that I did not read the "How to buy a 914" book before before buying this car. (IMG:style_emoticons/default/mad.gif)
Dropped the engine and tranny last week, drilled out some rivets on a few sheet metal patches in the hell hole and found it to be even worse than I expected.
My ultimate goal is to have a safe and reliable daily driver that can be used for the occasional autocross. Not looking for a show car.
At some point, the right rear suspension ear most have rusted off so the PO had a new one welded in. Additionally, some sketchy metal work was done to the bottom of the long, the right jack post area and right engine bay area. Repair pics:
Pics of the long and hell hole:
Does it make sense to try to patch the existing long up in the hell hole or am I looking at a complete replacement? The area where the engine mount bracket attaches is pretty rusty at the top.
Thanks,
Bob
charliew
post May 19 2010, 09:21 AM
Somebody might make them but they are easy to make with a piece of square tubing with nuts welded in the ends or turnbuckles to apply a little tension on the gap. You can sheetmetal screw a bracket on the inner jamb inside at the front and go to the seat belt shoulder mount on the inside of the targa. Some guys have just welded any thing inbetween the opening and then later cut it out and sand the spot down. I would add the braces before you jack it up if you can. Actually a X crossbrace, from side to side would also keep it from twisting. Another place to measure is at the top opening but the windshield frame bends pretty easily so the door is the important place. I would raise the car and support it at the ends and center at the same places on both sides. You won't be able to use the back donuts as thats where you are working. If the door gap is good, with the braces, you need to check this as you go, jack it up under the susp and see what happens, if it stays ok then that may be the way to support it till you get supports under the long and at the front and rear. Then remove the suspension support, but be safe. You need to look at the other threads that have done this before you start. I would make a list of how far you are going in to it and the inside pieces will need to go on first. Get to know the layers before you start. There is a double layer inside the long. Try not to get any area too hot while you are welding. Metal shrinks as it cools sometimes more than you can imagine.
Buy lots of beer and get the other 914 guys to give some advice and support.
- Lo-Fi Version Time is now: 7th December 2025 - 05:28 PM
