VaccaRabite |
En Garde! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 13,752 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region ![]() ![]() |
My 2056 is getting elevated oil temps on the freeway. I am using a high volume pump, and seeing about 40 pounds of pressure on the freeway when my oil is up to temp.
What I think is happening is that there is too much pressure, and the oil is not being pumped through the oil cooler due to the check valve closing the passage. However, this is just a guess, as I don't have any way to test it. All I know is that when I am driving at revs, oil temp goes up and if I keep driving at higher revs the oil temps stay up). if I drop revs, oil temps fall back into place, but I can't do that on the freeway without building a lot of head heat. Before I go through the trouble and expense of adding an oil cooler, I want to make sure that I have checked out the simple fixes first. What do I do to make sure oil if going through the oil cooler? What is the point where pressure cuts off passage through the cooler? All tin is in place, and fan housing flaps divert air over the oil cooler 100% of the time (no thermostat in place, so the flaps are always set to cool). Zach |
ChrisFoley |
I am Tangerine Racing ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,990 Joined: 29-January 03 From: Bolton, CT Member No.: 209 Region Association: None ![]() ![]() |
Higher pressure from a high volume pump isn't necessarily going to increase the flow rate through the cooler.
At a certain point, the primary pressure relief valve will open and allow some oil to bypass the cooler. The flow rate through the cooler is therefore regulated to a large degree by the pressure relief valve. The viscosity of the oil changes with temperature. When the oil is very hot it won't develop as much pressure and will flow more quickly through narrow passages such as in the cooler and between the bearings and crank. Even though it is flowing faster and has less time to dump heat, the delta T is greater thereby increasing the rate of thermal transfer. |
Lo-Fi Version | Time is now: 3rd July 2025 - 07:05 AM |
