Fuel Pump Diagnostics |
solex |
Mar 21 2010, 12:40 PM
Senior Member Group: Members Posts: 789 Joined: 12-January 05 From: Long Island, NY Member No.: 3,439 Region Association: North East States |
Hi All,
Need a little help to diagnose a fuel pump problem in a 75, I do not hear the pump when I turn the key to the run position. The car was running, I had a few occasions where it would not start, let it sit for a few days and it was start right up. The grounds: under the relay board, battery and transmission have all been cleaned. All fuses are good. The relay is working as I can hear it click into position. When the key is in the run position relay terminals 30 and 85 shows 12 volts. Terminal 86 show 0.03 volts and terminal 87 show zero volts. There is no voltage at either of the fuel pump terminals. The readings at the relay is counter to to what Haynes states (86 should read 12 and 85 should be ground). I not sure where to check next, really do not want to pull the tank. Any assistance would be appreciated. Thanks, Dan |
swl |
May 25 2010, 03:14 PM
Senior Member Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
That looks pretty conclusive Dan. And also where you were at a couple of weeks ago before we derailed you. There are still some things that don't quite fit but definitely time to resort to the new pump.
It would be interesting to do a post-mortem on the pump and see what is causing it to shut down. In terms of the voltage to the pump it should in theory be the same as the voltage at the battery (car not running). If the voltage at the pump is lower than at the battery then the losses are due to contact resistances - relay, harness plugs, ground point. Even the wire itself has some small resistance. Looking forward to hearing the outcome on this one. |
Lo-Fi Version | Time is now: 2nd June 2024 - 05:29 AM |
