> Wonky headlight..., back again (post 17)
VaccaRabite
post Apr 13 2010, 07:45 AM
En Garde!
Last fall, the drivers side headlight went out. it was miswired - I am not sure how it was working to begin with. Fixed the wiring, and everything worked great.
Saturday I washed my car.
Today, I decided to drive to work, even though rain was threatening, weather said I would be clear. But it was cloudy this morning, so I put the lights on. I got no beam from the drivers side light, again.
Also, I noticed that the charging system was right at 12 volts, where it is usually at 13. May be unrelated.
I know that the wiring at the light is correct. Any idea where to start trouble shooting?
Zach
Spoke
post May 25 2010, 10:11 PM
Jerry
I wouldn't expect a rubbed wire or anything like that. If a wire were rubbing against anything you would have let the smoke out and it would have made a real mess and stink.
What I think you have is 30 year old oxidation on all the connectors. When you look at the connectors, there is a very very little bit of the connector actually touching the spade.
All around that small area of contact is exposed metal which oxidizes immediately and it builds over time. Just a little vibration and the vibration may be caused by heating and contraction, and the metal contact is now rubbing on an oxidized part of the lug and you get a bad connection and voltage drop.
Sometimes jiggling the wire (this is an official electrical secret) will improve the contact and your lights will get brighter. This is a hint as to your voltage loss.
You switch *may* be ok, just the spades and connectors are oxidized and need cleaned off with 400 to 1000 grit wet-or-dry sandpaper; dry of course. Contact cleaner sprayed after the sanding will remove the residue but it won't by itself, remove the oxidation. Your spades should look nice and shiny.
Also clean the edges of the connectors. I do this with a real little file. Sometimes I tighten the connectors by crimping (just slightly) the rolled parts of the connector.
Just this weekend I fixed the electric passenger window on my 911. The window would go down but not up unless the button was pressed time and time again, and even then it didn't go up fast. The culprit was; you guessed it; oxidized lugs. Cleaned the lugs with 400 grit W-or-D sandpaper and crimped the connectors and the window works like a charm. The oxidation on the connectors on my 911 is only 24 years old.
Vacca Rabite   Wonky headlight...   Apr 13 2010, 07:45 AM
tradisrad   I also see a voltage drop when my lights are on fr...   Apr 13 2010, 07:49 AM
underthetire   I've had a problem with my old sealed beams be...   Apr 13 2010, 11:11 AM
jsayre914   dont woory about the voltage drop zach, it isnt a ...   Apr 13 2010, 12:07 PM
Vacca Rabite   Mike may be over today. He was planning on being o...   Apr 13 2010, 12:10 PM
TROJANMAN   Did you check the relay?   Apr 13 2010, 12:20 PM
Drums66   Did you check the relay? ECHO echo(also headlig...   Apr 13 2010, 12:43 PM
Vacca Rabite   Not yet. Noticed the light was out when I pulled ...   Apr 13 2010, 12:24 PM
Spoke   Start checking voltages right at the light. If yo...   Apr 13 2010, 02:32 PM
Vacca Rabite   When I got home tonight I took a few minutes to tr...   Apr 13 2010, 07:03 PM
Dave_Darling   Sounds like the brighter light is grounding itself...   Apr 13 2010, 09:10 PM
Vacca Rabite   Dave, I considered this. I think it is probably t...   Apr 14 2010, 06:06 AM
Vacca Rabite   Okay, so new puzzle. I fixed the first problem. ...   Apr 16 2010, 08:41 PM
Dave_Darling   How did you measure the voltage? Between which an...   Apr 16 2010, 09:20 PM
Vacca Rabite   I measured voltage at the headlight terminals. Wh...   Apr 17 2010, 06:52 AM
Vacca Rabite   Well, Mike helped me chase the problem, and we fou...   Apr 19 2010, 08:08 AM
Vacca Rabite   So, this problem still exists. I had been letting...   May 24 2010, 09:47 PM
Spoke   Low beams are only getting 6 volts at the bulb. ...   May 25 2010, 11:12 AM
Dr Evil   Maybe I can help you out sometime :rolleyes:   May 24 2010, 11:06 PM
Vacca Rabite   Maybe I can help you out sometime :rolleyes: Did...   May 25 2010, 06:29 AM
Dr Evil   I remember nothing. I would have to start at it so...   May 25 2010, 09:41 AM
Vacca Rabite   One test that I am going to do this evening, which...   May 25 2010, 01:11 PM
Vacca Rabite   Just finished my wire test. Everything from the fu...   May 25 2010, 06:20 PM
Dr Evil   I may have a spare. I know where I can get one, an...   May 25 2010, 06:45 PM
Spoke   Disconnect NEG from Battery and pull out your swit...   May 25 2010, 08:38 PM
Vacca Rabite   I'm back inside for the night, and I made prog...   May 25 2010, 08:57 PM
Spoke   I wouldn't expect a rubbed wire or anything li...   May 25 2010, 10:11 PM
Vacca Rabite   I'll clean them tonight and report back. I am ...   May 26 2010, 06:49 AM
- Lo-Fi Version Time is now: 17th September 2026 - 03:12 AM
