| tod914 |
May 26 2010, 06:07 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
Put in a nos bosch 3 port pump in my car after changing all the fuel lines. There is gas in both the feed and return line from the firewall to the pump.. no kinked lines there. I checked and checked my fuel line configuration. All seems good..
fat line from fire wall to step hose to filter to S / top of the pump. D line to feed into engine bay. R has the 2 return lines and the bottom of the pump. Now the pump has the correct bosch numbers on it, but does not have the S D R on it. I would think it's the same as my old pump even though it's not marked like that. fuel routing in the engine bay is fine. been over that several times. the pump turns on fine when I turn the key 1/2 way. I tried that like 30 times to try to get pressure to build up. nadda.. even tried pulling feed line in the engine bay to see if that helped. Even ran it directly from the battery for like 10 seconds like the instructions said. Any suggestions on how to get this pump to prime/push fuel? |
| swl |
May 26 2010, 07:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,409 Joined: 7-August 05 From: Kingston,On,Canada Member No.: 4,550 Region Association: Canada |
Dr. 914 - please pick up the white courtesy phone!
| detoxcowboy |
May 26 2010, 08:14 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
tod914 fuel pump problem.. won't prime for some reason May 26 2010, 06:07 PM
tod914 Would clamping the return feed into the pump help ... May 26 2010, 06:14 PM
SLITS "R" is the one next to the aluminum cap.... May 26 2010, 06:15 PM
tod914 That's the way it's hooked up Ron, thanks.... May 26 2010, 06:19 PM
swl test to see if fuel is being delivered through the... May 26 2010, 07:08 PM
tod914 Steve, absolutely nothing comes out of "D... May 26 2010, 07:12 PM
detoxcowboy tod, please post how this comes out? yours is not ... May 26 2010, 07:18 PM
swl Should be easy check out. Just pull the R and rou... May 26 2010, 07:21 PM
tod914 Great, thanks for the tips. I'll get on it to... May 26 2010, 07:31 PM
dr914@autoatlanta.com
Dr. 914 - please pick up the white courtesy phone... May 27 2010, 07:27 PM
swl found the thread I was thinking about.
http://www... May 26 2010, 07:54 PM
tod914 Cool deal, I'll message Paul and see if our pu... May 26 2010, 08:02 PM
swl you know after re-reading that thread I wonder if ... May 26 2010, 08:10 PM
SLITS
you know after re-reading that thread I wonder if... May 26 2010, 08:18 PM
tod914 I also tried running the pump with the leeds swapp... May 26 2010, 08:19 PM
tod914 Here's some shots if you guys don't mind d... May 26 2010, 08:28 PM
avidfanjpl I have 2 3 port pumps - 1 Bosch in the car and a s... May 27 2010, 12:49 AM
Tom_T IMHO - you're far better off with a rebuilt Bo... May 27 2010, 01:09 AM
AvalonFal Yeah, I'm the one that had the crazy Chinese f... May 27 2010, 08:44 AM
SLITS
Yeah, I'm the one that had the crazy Chinese ... May 27 2010, 01:48 PM
tod914 Aaaarg.. now the f'n thing is leaking at the b... May 27 2010, 12:39 PM
Aaaarg.. now the f'n thing is leaking at the ... May 27 2010, 07:30 PM
Tom_T Anyone use the AA "repro" 3 port fuel pu... May 27 2010, 01:58 PM
Anyone use the AA "repro" 3 port fuel p... May 27 2010, 07:28 PM
Tom_T
Anyone use the AA "repro" 3 port fuel ... May 28 2010, 02:00 AM
Nürburg Nomad Hey Tod914... can you tell me where you bought tho... May 27 2010, 02:51 PM
tod914 I believe I got some from my local VW dealer and o... May 27 2010, 03:02 PM
tod914 Good deal George, I'll touch base with you guy... May 27 2010, 09:45 PM![]() ![]() |
Lo-Fi Version | Time is now: 13th March 2026 - 03:59 AM |
