> Anyone have pics of a J West shift rod install?, Stock shift rod wont clear my road race oil pan
Mike Bellis
post May 27 2010, 05:33 PM
Resident Electrician
I installed a Road Race oil pan on my V8. Now my shift rod is in the way. I need to decide on a J West or cable setup. Anyone have pics of the J west system from the firewall to the tranny?
post May 27 2010, 05:39 PM
Resident German
QUOTE(kg6dxn @ May 27 2010, 04:33 PM) *
http://www.914world.com/bbs2/index.php?showtopic=70331
You make your own shift rod using the one supplied by James. On my car, it's a straight line from the firewall coupler to the sideshift console coupler.
You can make the rod any shape, as long as both ends are in the same plane ...
(IMG:style_emoticons/default/shades.gif) Andy
(IMG:http://www.914world.com/bbs2/uploads/post-179-1182814172.jpg)
Mike Bellis
post May 27 2010, 05:48 PM
QUOTE(SirAndy @ May 27 2010, 04:39 PM) *
There lies my other problem. The Renegade kit lowers the tranny 1 inch and moves it back 1.25 inches. Not on the same plain anymore. I'm going to need to offset the rod and use 3 or4 U-joints with a carrier bearing in the middle, maybe on the engine cradle. I no longer have a strait shot. The road race pan kicks out 3 inches on both sides of the pan.
post May 27 2010, 05:59 PM
Resident German
QUOTE(kg6dxn @ May 27 2010, 04:48 PM) *
The JWest kit comes with U-joints on both ends. Moving the tranny around does not matter. Like i said above, as long as you get both ends in the same plane, you're good.
The same plane on the movable end of the u-joints that is.
If you can point each end of the u-joints at each other and there's nothing in-between that line, you got a straight shot, meaning both ends are in the same plane.
Plane as in 3D, not 2D.
PS: See pics in my thread linked above ...
kg6dxn   Anyone have pics of a J West shift rod install?   May 27 2010, 05:33 PM
JWest   The JWest linkage will give you less room than sto...   May 27 2010, 05:37 PM
kg6dxn   The JWest linkage will give you less room than st...   May 27 2010, 05:42 PM
SirAndy   Anyone have pics of the J west system from the fi...   May 27 2010, 05:39 PM
kg6dxn   Anyone have pics of the J west system from the f...   May 27 2010, 05:48 PM
SirAndy   There lies my other problem. The Renegade kit low...   May 27 2010, 05:59 PM
kg6dxn   Here's my view from the rear.   May 27 2010, 05:59 PM
SirAndy   Here's my view from the rear. No way that is ...   May 27 2010, 06:02 PM
GS Guy   My solution to a similar problem - I have 0 room t...   May 27 2010, 06:16 PM
kg6dxn   My solution to a similar problem - I have 0 room ...   May 27 2010, 06:24 PM
kg6dxn   I really don't want to cut the pan. It is baff...   May 27 2010, 06:18 PM
McMark   A plane is by definition 2D. :P   May 27 2010, 06:39 PM
SirAndy   A plane is by definition 2D. :P But it is orien...   May 27 2010, 07:43 PM
jimkelly   put a standard oil pan on it - most straight forwa...   May 27 2010, 06:41 PM
kg6dxn   put a standard oil pan on it - most straight forw...   May 27 2010, 06:44 PM
Eddie914   How about moving the exhaust outboard? Eddie   May 27 2010, 08:02 PM
kg6dxn   How about moving the exhaust outboard? Eddie R...   May 27 2010, 08:55 PM
computers4kids   My motor motor was built for a circle track car an...   May 27 2010, 10:01 PM
- Lo-Fi Version Time is now: 1st August 2025 - 12:21 PM
