> Model Specific Information
> Gas tank resto, Final Phase - Tank
Pat Garvey
post May 15 2010, 08:27 PM
Do I or don't I...........?
As many of you know, I have a tank problem, from fibe years (almost) gas sitting in the tank. I bought a good tank, with a bad finish. I'm documenting the rstor of it here.
Phase One - the easy part. I used the evap tank to rehone my finishing skills. It was presentable to most, but not to me. Stripped to bare metal, primed, wet sanded & 3 final coats of black satin. Three days later - wet sanded with 800 grit, Turtle Wax rubbing compound, and Meguiars Show car Glaze. Too shiney, but blame it on intense wet sanding!
Pics show it all.
Pat
Phase Two - Fuel collar. Not too bad after some high grit sanding. We'll see how tha finish coat sticks. Stay tuned, because the tank comes next!
For those who think I'm sitting on my ass, pontificating - think again!
Pat
Pat Garvey
post May 22 2010, 04:08 PM
Well, I started sanding the tank today. Initially, I was trying 400 grit and it did well at smoothing some areas. Other areas had been heavily sprayed by he PO, resulting in heavy orange-peel, and 400 wouldn't do the job (just kept loading up with paint). So I switched to my 3 head rotary & 150 grit. Worked well at removing the heavy stuff, but quickly cut through everything, to bare metal in some areas, before I abandoned it for the day.
I have two questions for any experts out there:
1. Is it really necessary for me to take the entire tank to bare metal? I'll do it, but just wonder....there is a very good basic finish under the black topcoat.
2. I'll be straying from my usual paint choices. Will be using L43 Gray-Black paint, provided by Tod914, so I'll need a good automotive primer. Suggestions?
This is what I'm starting with......
MrKona
post May 23 2010, 11:18 PM
QUOTE(Pat Garvey @ May 22 2010, 02:08 PM) *
Pat - I second the L43. I recently repainted an original four-spoke steering wheel with the L43 I purchased from Wolfsurg West. I'm also going to be refinishing a fuel tank soon. Last night I compared the relatively untouched underside of the expansion tank to my newly re-painted steering wheel, and the L43 was pretty much dead-on.
Pat Garvey
post May 27 2010, 06:37 PM
QUOTE(MrKona @ May 23 2010, 11:18 PM) *
Guys - I just want to clarify something here! My original tank, evaporator and fuel collar still sit under the front boot. They are ORIGINAL to this 914. Just wanted to get that straight.
Now, the original fuel collar and expansion tank (complete with decal) are satin black. The tank is original and gray-black. This is what I'm trying to reproduce - the tank! The other parts will be available for sale soon, and they are sweet!
914 gas tanks came in two verifiable shades (a third is unverified) - satin black, and gray/satin black. My 72 was a transition car. It came with gray/satin black tank. Pics available.
If I continue to take my time, and dodge the high humidtity, my replacement tank should equal my original (sans interior rust). Watch for updates.
Pat Garvey   Gas tank resto   May 15 2010, 08:27 PM
Tom_T   Pat - what was the red primer you used (name/brand...   May 15 2010, 11:18 PM
Pat Garvey   Pat - what was the red primer you used (name/bran...   May 16 2010, 06:41 PM
Pat Garvey   Pat - what was the red primer you used (name/bra...   Jun 8 2010, 06:35 PM
tod914   Pat looks real nice. I used the Mequires too. De...   May 16 2010, 05:35 PM
Pat Garvey   Pat looks real nice. I used the Mequires too. D...   May 16 2010, 06:49 PM
Tom_T   Thanx for the step-by-step Pat! I'll hav...   May 17 2010, 12:38 AM
Pat Garvey   So, the collar is now done. Came ou pretty nice - ...   May 20 2010, 06:49 PM
Tom_T   So, the collar is now done. Came ou pretty nice -...   May 21 2010, 12:36 AM
Pat Garvey   So, the collar is now done. Came ou pretty nice ...   May 21 2010, 06:06 PM
Tom_T   What! Works in hillbillyland! Careful ...   May 21 2010, 06:22 PM
kharma   Watching with great interest... redoing all the fu...   May 21 2010, 06:26 AM
Pat Garvey   Watching with great interest... redoing all the f...   May 21 2010, 06:11 PM
tod914   A jig to paint the tank Pat? I layed mine on a la...   May 21 2010, 09:20 AM
Pat Garvey   A jig to paint the tank Pat? I layed mine on a l...   May 21 2010, 06:03 PM
tod914   Pat your more meticulous than I thought! Now ...   May 21 2010, 07:03 PM
Pat Garvey   Well, I started sanding the tank today. Initially...   May 22 2010, 04:08 PM
MrKona   2. I'll be straying from my usual paint cho...   May 23 2010, 11:18 PM
Pat Garvey   2. I'll be straying from my usual paint ch...   May 27 2010, 06:37 PM
Tom_T   Pat, the problem you need to assess is whether the...   May 23 2010, 08:19 PM
scotty b   No need to go to bare metal unless there is rust s...   Jun 2 2010, 07:28 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 8 2010, 06:46 PM
Pat Garvey   Update(and I know most of you think I'm freaki...   Jun 2 2010, 07:38 PM
avidfanjpl   Hey Pat, I knew I should have put up info on my t...   Jun 2 2010, 11:59 PM
Pat Garvey   Hey Pat, I knew I should have put up info on my ...   Jun 3 2010, 08:45 PM
tod914   John, I like some of the POR products too. After ...   Jun 4 2010, 12:05 AM
Pat Garvey   John, I like some of the POR products too. After...   Jun 6 2010, 06:03 PM
avidfanjpl   Hey Pat and Tod, You guys are WAY ahead on things...   Jun 4 2010, 12:31 AM
tod914   Cool deal John. When did you move out of NJ?   Jun 6 2010, 10:22 AM
scotty b   You do realize that the gas tanks were never finis...   Jun 13 2010, 02:13 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 13 2010, 06:43 PM
tod914   Scotty, I think Pat was going to add the factory r...   Jun 13 2010, 02:16 PM
scotty b   I should have known your nipples were perfect Pat ...   Jun 13 2010, 07:08 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 14 2010, 06:08 PM
Pat Garvey   OK, now I need some help! I primed the tank w...   Jun 15 2010, 08:03 PM
Tom_T   OK, now I need some help! I primed the tank ...   Jun 15 2010, 11:12 PM
Pat Garvey   OK, now I need some help! I primed the tank...   Jun 16 2010, 08:09 PM
Tom_T   [quote name='Tom_T' post='1331290' date='Jun 15 2...   Jun 16 2010, 10:38 PM
Jasfsmith   I know that most of think I'm whacko, but I ...   Jun 16 2010, 07:51 AM
Pat Garvey   I know that most of think I'm whacko, but I...   Jun 16 2010, 07:51 PM
tod914   That's too funny Scotty. Do you think Pat wax...   Jun 15 2010, 08:38 PM
Jon Fernandes   Pat, steel wool may leave scratches in the primer....   Jun 15 2010, 08:53 PM
Pat Garvey   Ok, here's where I am today. The zinc-rich pr...   Jun 18 2010, 04:17 PM
tod914   Think your looking for BusDepot.com. WolfsburgWes...   Jun 19 2010, 09:40 AM
Tom_T   Think your looking for BusDepot.com. WolfsburgWe...   Jun 19 2010, 02:54 PM
Pat Garvey   Think your looking for BusDepot.com. WolfsburgW...   Jun 19 2010, 04:48 PM
Pat Garvey   Well, I now have 3 coats of L43 on the front half ...   Jun 22 2010, 07:23 PM
Tom_T   Well, I now have 3 coats of L43 on the front half...   Jun 22 2010, 07:39 PM
tod914   Wow not grey enough? I'm very surprized to he...   Jun 23 2010, 08:29 AM
Pat Garvey   Wow not grey enough? I'm very surprized to h...   Jun 25 2010, 06:47 PM
Niklas   Hi! Why are you not using powdercoating ? In ...   Jun 23 2010, 10:23 AM
Pat Garvey   Hi! Why are you not using powdercoating ? In...   Jun 25 2010, 06:41 PM
Cairo94507   Man, are we ever going to see this gas tank? Let...   Jun 25 2010, 08:41 PM
Pat Garvey   Man, are we ever going to see this gas tank? Let...   Jun 27 2010, 06:55 PM
tod914   I went through the same thing with my intake runne...   Jun 25 2010, 11:19 PM
Pat Garvey   I went through the same thing with my intake runn...   Jun 29 2010, 07:43 PM
Cairo94507   :popcorn:   Jun 28 2010, 07:14 PM
tod914   Pat I think it has too much green too it. Let me ...   Jun 29 2010, 09:38 PM
Pat Garvey   Well, I went through several days of 95-105 temps ...   Jul 9 2010, 04:49 PM
Tom_T   So why aren't those chrome wheels on Fritz? T...   Jul 9 2010, 05:06 PM
Pat Garvey   So why aren't those chrome wheels on Fritz? ...   Jul 9 2010, 06:19 PM
Tom_T   You do it & do it right, or redo it! I ...   Jul 9 2010, 09:01 PM
Pat Garvey   You do it & do it right, or redo it! I...   Jul 12 2010, 08:00 PM
Pat Garvey   Refinishing complete! Jeez! All it needs ...   Jul 13 2010, 07:43 PM
Pat Garvey   Refinishing complete! Jeez! All it needs...   Jul 14 2010, 07:49 PM
Tom_T   Well Pat - it looks great on its own, but I can de...   Jul 13 2010, 07:50 PM
Pat Garvey   Well Pat - it looks great on its own, but I can d...   Jul 14 2010, 07:41 PM
Tom_T   [quote name='Tom_T' post='1343215' date='Jul 13 2...   Jul 15 2010, 10:36 AM
Pat Garvey   [quote name='Tom_T' post='1343215' date='Jul 13 ...   Jul 16 2010, 05:46 PM
scotty b   :blink: your gas tank looks better than most peopl...   Jul 14 2010, 02:18 PM
Pat Garvey   :blink: your gas tank looks better than most peop...   Jul 14 2010, 07:32 PM
tod914   Very nice Pat. Tank appears flawless. Drop it in...   Jul 14 2010, 05:58 PM
Tom_T   Very nice Pat. Tank appears flawless. Drop it i...   Jul 14 2010, 06:16 PM
Tom_T   Pat - I just meant that in my 73 914-2.0's tan...   Jul 16 2010, 06:12 PM
Pat Garvey   Pat - I just meant that in my 73 914-2.0's ta...   Jul 16 2010, 06:31 PM
Tom_T   Thanx Pat - I've had many surprises so far - s...   Jul 16 2010, 06:36 PM
Pat Garvey   Thanx Pat - I've had many surprises so far - ...   Jul 16 2010, 07:33 PM
Tom_T   Thanx Pat - I've had many surprises so far -...   Jul 16 2010, 07:41 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:27 AM
