> fuel pump problem.. won't prime for some reason, Dr 914/George could you verify markings on China pumps please
tod914
post May 26 2010, 06:07 PM
Put in a nos bosch 3 port pump in my car after changing all the fuel lines. There is gas in both the feed and return line from the firewall to the pump.. no kinked lines there. I checked and checked my fuel line configuration. All seems good..
fat line from fire wall to step hose to filter to S / top of the pump. D line to feed into engine bay. R has the 2 return lines and the bottom of the pump. Now the pump has the correct bosch numbers on it, but does not have the S D R on it. I would think it's the same as my old pump even though it's not marked like that. fuel routing in the engine bay is fine. been over that several times. the pump turns on fine when I turn the key 1/2 way. I tried that like 30 times to try to get pressure to build up. nadda.. even tried pulling feed line in the engine bay to see if that helped. Even ran it directly from the battery for like 10 seconds like the instructions said.
Any suggestions on how to get this pump to prime/push fuel?
tod914
post May 27 2010, 12:39 PM
Aaaarg.. now the f'n thing is leaking at the bolts. Having Brad at AA working on one for me. Thinking no way this is oem for it to do this. Not priming/pumping out of the right port, no markings on top by ports. Left a message with the vendor whom sold it to me. I'll keep you guys posted.
dr914@autoatlanta.com
post May 27 2010, 07:30 PM
QUOTE(tod914 @ May 27 2010, 11:39 AM) *
We have 50 genuine bosch rebuilds on the way.
tod914   fuel pump problem.. won't prime for some reason   May 26 2010, 06:07 PM
tod914   Would clamping the return feed into the pump help ...   May 26 2010, 06:14 PM
SLITS   "R" is the one next to the aluminum cap....   May 26 2010, 06:15 PM
tod914   That's the way it's hooked up Ron, thanks....   May 26 2010, 06:19 PM
swl   test to see if fuel is being delivered through the...   May 26 2010, 07:08 PM
tod914   Steve, absolutely nothing comes out of "D...   May 26 2010, 07:12 PM
detoxcowboy   tod, please post how this comes out? yours is not ...   May 26 2010, 07:18 PM
swl   Should be easy check out. Just pull the R and rou...   May 26 2010, 07:21 PM
tod914   Great, thanks for the tips. I'll get on it to...   May 26 2010, 07:31 PM
swl   Dr. 914 - please pick up the white courtesy phone...   May 26 2010, 07:38 PM
detoxcowboy   Dr. 914 - please pick up the white courtesy phone...   May 26 2010, 08:14 PM
dr914@autoatlanta.com   Dr. 914 - please pick up the white courtesy phone...   May 27 2010, 07:27 PM
swl   found the thread I was thinking about. http://www...   May 26 2010, 07:54 PM
tod914   Cool deal, I'll message Paul and see if our pu...   May 26 2010, 08:02 PM
swl   you know after re-reading that thread I wonder if ...   May 26 2010, 08:10 PM
SLITS   you know after re-reading that thread I wonder if...   May 26 2010, 08:18 PM
tod914   I also tried running the pump with the leeds swapp...   May 26 2010, 08:19 PM
tod914   Here's some shots if you guys don't mind d...   May 26 2010, 08:28 PM
avidfanjpl   I have 2 3 port pumps - 1 Bosch in the car and a s...   May 27 2010, 12:49 AM
Tom_T   IMHO - you're far better off with a rebuilt Bo...   May 27 2010, 01:09 AM
AvalonFal   Yeah, I'm the one that had the crazy Chinese f...   May 27 2010, 08:44 AM
SLITS   Yeah, I'm the one that had the crazy Chinese ...   May 27 2010, 01:48 PM
tod914   Aaaarg.. now the f'n thing is leaking at the b...   May 27 2010, 12:39 PM
dr914@autoatlanta.com   Aaaarg.. now the f'n thing is leaking at the ...   May 27 2010, 07:30 PM
Tom_T   Anyone use the AA "repro" 3 port fuel pu...   May 27 2010, 01:58 PM
dr914@autoatlanta.com   Anyone use the AA "repro" 3 port fuel p...   May 27 2010, 07:28 PM
Tom_T   Anyone use the AA "repro" 3 port fuel ...   May 28 2010, 02:00 AM
Nürburg Nomad   Hey Tod914... can you tell me where you bought tho...   May 27 2010, 02:51 PM
tod914   I believe I got some from my local VW dealer and o...   May 27 2010, 03:02 PM
tod914   Good deal George, I'll touch base with you guy...   May 27 2010, 09:45 PM
- Lo-Fi Version Time is now: 13th March 2026 - 05:28 AM
