| TorqueJunkie |
May 27 2010, 08:34 PM
Newbie ![]() Group: Members Posts: 48 Joined: 25-May 10 From: Baltimore, MD Member No.: 11,760 Region Association: None |
I have a 1973 914/6 conversion with 2.4 L engine(being rebuilt now), and I am running the Alloy "S" brake calipers up front. I am looking to upgrade the front brakes. Boxster calipers are cheaper than the Big reds and a bit smaller as I would like to run a 17" wheel or smaller.
Anyone have the boxster calipers installed? Which rotors did you use? Adapters? I have an old set of Bremtek calipers that I might use if I can find some seal kits for them still. New to these forums, but love all the stuff on this site...especially all the racing pics |
| TorqueJunkie |
May 28 2010, 05:32 AM
Thanks for the input. The willwood set-up looks nice. I will take a look and see what I can find. I believe for now the alloy S calipers are enough, but might want to upgrade and the engine will have a bit more power this time around. and looking to add wider tires as well.
TorqueJunkie Brake upgrades? What do you use? May 27 2010, 08:34 PM
stewteral
I have a 1973 914/6 conversion with 2.4 L engine(... May 27 2010, 09:26 PM
camaroz1985
Hey Torque Junkie,
For my $$, you can... May 28 2010, 07:50 AM
stewteral
[quote name='stewteral' post='1324728' date='May ... May 28 2010, 10:45 AM
rickthejetman
I have a 1973 914/6 conversion with 2.4 L engine... May 30 2010, 06:18 PM
stewteral
[quote name='stewteral' post='1324728' date='May ... May 30 2010, 11:19 PM
campbellcj Depending how extreme your car is, and your use fo... May 27 2010, 10:33 PM
stewteral
Depending how extreme your car is, and your use f... May 27 2010, 11:03 PM
J P Stein "Upgrade" in regard to 914 brakes is ba... May 28 2010, 09:16 AM
brant I think you just need to buy the proper pads
I dou... May 30 2010, 08:42 PM
Eric_Shea Go watch an HSR 2 Litre Challenge event. If you... May 30 2010, 11:51 PM
ArtechnikA For a good (did not say cheap) street/AX pad, go g... May 31 2010, 06:35 AM
TorqueJunkie I am going to keep my Alloy S calipers for now and... Jun 4 2010, 08:32 PM
J P Stein A good addition to S calipers is a set of Stainles... Jun 5 2010, 05:56 AM
brant and I've had good luck with the Pagid 4S stree... Jun 5 2010, 07:38 AM
TorqueJunkie I have stainless pistons in them. Car sat out and... Jun 5 2010, 08:22 PM
J P Stein
I have stainless pistons in them. Car sat out an... Jun 6 2010, 08:04 AM
brant I think you will find that the modern carbon pads ... Jun 6 2010, 08:57 AM
naro914 just to add to this, I have 993 rear calipers on t... Jun 7 2010, 07:19 PM
naro914 OK, i just looked at this picture and realized I a... Jun 7 2010, 07:25 PM
andys
OK, i just looked at this picture and realized I ... Jun 8 2010, 09:15 AM
naro914 23 mm. Jun 8 2010, 09:22 AM
naro914 Huey should be back at the shop next week or so to... Jun 8 2010, 01:49 PM
Steve I'm running Boxster calipers front and rear. ... Jun 14 2010, 09:06 AM
MikeSpraggi Building my track car now. I am using 951 front ca... Jun 16 2010, 04:39 AM
rickthejetman
Building my track car now. I am using 951 front c... Jun 16 2010, 05:35 PM
MikeSpraggi
Building my track car now. I am using 951 front ... Jul 2 2010, 04:36 AM
brant I know vintage racing out here requires the brakes... Jul 2 2010, 09:51 AM
MikeSpraggi Brant, I know what you are saying about the origin... Jul 2 2010, 10:36 AM
brant
Brant, I know what you are saying about the origi... Jul 4 2010, 07:38 AM
Randal I agree with JP that the original poster doesn... Jul 4 2010, 11:46 AM
Eric_Shea Carrera calipers are the heaviest calipers ever ma... Jul 8 2010, 04:00 PM
J P Stein
Carrera calipers are the heaviest calipers ever m... Jul 8 2010, 05:45 PM
ArtechnikA
You're right, Eric, but I had no luck with 91... Jul 8 2010, 05:50 PM
Eric_Shea
:agree: Probably saved a little weight with tha... Jul 12 2010, 08:58 AM
J P Stein It came dow to time, money, & effort.I knew th... Jul 12 2010, 10:38 AM
jt914-6 OK..there are lots of brake "upgrades" t... Sep 4 2010, 06:54 PM
TorqueJunkie Well I finally got my brakes off and rebuilt. All... Feb 19 2011, 11:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th January 2026 - 03:13 AM |
