| TorqueJunkie |
May 27 2010, 08:34 PM
Newbie ![]() Group: Members Posts: 48 Joined: 25-May 10 From: Baltimore, MD Member No.: 11,760 Region Association: None |
I have a 1973 914/6 conversion with 2.4 L engine(being rebuilt now), and I am running the Alloy "S" brake calipers up front. I am looking to upgrade the front brakes. Boxster calipers are cheaper than the Big reds and a bit smaller as I would like to run a 17" wheel or smaller.
Anyone have the boxster calipers installed? Which rotors did you use? Adapters? I have an old set of Bremtek calipers that I might use if I can find some seal kits for them still. New to these forums, but love all the stuff on this site...especially all the racing pics |
| stewteral |
May 27 2010, 09:26 PM
Old Member ![]() ![]() Group: Members Posts: 384 Joined: 4-December 07 From: Camarillo, CA Member No.: 8,424 Region Association: Southern California |
I have a 1973 914/6 conversion with 2.4 L engine(being rebuilt now), and I am running the Alloy "S" brake calipers up front. I am looking to upgrade the front brakes. Boxster calipers are cheaper than the Big reds and a bit smaller as I would like to run a 17" wheel or smaller. Anyone have the boxster calipers installed? Which rotors did you use? Adapters? I have an old set of Bremtek calipers that I might use if I can find some seal kits for them still. New to these forums, but love all the stuff on this site...especially all the racing pics Hey Torque Junkie, For my $$, you can't beat WILWOOD brakes! On my V8 conversion 914, I'm running 12.19" x 1.25" vented Wilwood rotors ($42 on summit) (http://www.summitracing.com/parts/WIL-160-2895/ (left) & http://www.summitracing.com/parts/WIL-160-2894/ (right) and the 4-piston Dynalite Calipers (http://www.summitracing.com/parts/WIL-120-6804/) $125. All you have to do is find the right aluminum rotor-hat to fit your application, drill them to you bolt pattern and make a very simple caliper mounting bracket. Don't be scared! When I mount the rotors, I use a dial indicator to get them centered within 0.005" and tighten them up. The bracket is also TOO simple..check out my pics and see. BTW: I did ALL this fabrication myself in my garage with only a drill press and a wire-feed welder. With the extra Chevy engine weight + driver, my rig weighs 2800 lbs and after a hard session on the Streets of Willow Springs, the front rotor only reach 420 deg. F., while the rears run at 300 deg. F. Enjoy, Terry Attached thumbnail(s) Attached image(s)
| camaroz1985 |
May 28 2010, 07:50 AM
Member ![]() ![]() Group: Members Posts: 90 Joined: 17-December 08 From: Bressler, PA Member No.: 9,857 Region Association: None |
Hey Torque Junkie, For my $$, you can't beat WILWOOD brakes! On my V8 conversion 914, I'm running 12.19" x 1.25" vented Wilwood rotors ($42 on summit) (http://www.summitracing.com/parts/WIL-160-2895/ (left) & http://www.summitracing.com/parts/WIL-160-2894/ (right) and the 4-piston Dynalite Calipers (http://www.summitracing.com/parts/WIL-120-6804/) $125. All you have to do is find the right aluminum rotor-hat to fit your application, drill them to you bolt pattern and make a very simple caliper mounting bracket. Don't be scared! When I mount the rotors, I use a dial indicator to get them centered within 0.005" and tighten them up. The bracket is also TOO simple..check out my pics and see. BTW: I did ALL this fabrication myself in my garage with only a drill press and a wire-feed welder. With the extra Chevy engine weight + driver, my rig weighs 2800 lbs and after a hard session on the Streets of Willow Springs, the front rotor only reach 420 deg. F., while the rears run at 300 deg. F. Enjoy, Terry So does the rotor hat have the bearings in it, or does it slide over a hub of some sort? |
| stewteral |
May 28 2010, 10:45 AM
Hey Torque Junkie, For my $$, you can't beat WILWOOD brakes! On my V8 conversion 914, I'm running 12.19" x 1.25" vented Wilwood rotors ($42 on summit) (http://www.summitracing.com/parts/WIL-160-2895/ (left) & http://www.summitracing.com/parts/WIL-160-2894/ (right) and the 4-piston Dynalite Calipers (http://www.summitracing.com/parts/WIL-120-6804/) $125. All you have to do is find the right aluminum rotor-hat to fit your application, drill them to you bolt pattern and make a very simple caliper mounting bracket. Don't be scared! When I mount the rotors, I use a dial indicator to get them centered within 0.005" and tighten them up. The bracket is also TOO simple..check out my pics and see. BTW: I did ALL this fabrication myself in my garage with only a drill press and a wire-feed welder. With the extra Chevy engine weight + driver, my rig weighs 2800 lbs and after a hard session on the Streets of Willow Springs, the front rotor only reach 420 deg. F., while the rears run at 300 deg. F. Enjoy, Terry So does the rotor hat have the bearings in it, or does it slide over a hub of some sort? Hi camaroz1985, The rotor hats slide on the wheel studs. In my case, I have adapter-spacers that bolt onto the Porsche 5-bolt pattern, retaining the rotor& hat with 5 studs sticking out in a Mustang pattern. Thus, I can set up the rotor position with a dial indicator, tighten the adapter and have the freedom to remove the wheels without disturbing the setup. I could easily see 914s using Porsche-Porsche pattern spacers to do the same thing. Best, Terry |
TorqueJunkie Brake upgrades? What do you use? May 27 2010, 08:34 PM
rickthejetman
I have a 1973 914/6 conversion with 2.4 L engine... May 30 2010, 06:18 PM
stewteral
[quote name='stewteral' post='1324728' date='May ... May 30 2010, 11:19 PM
campbellcj Depending how extreme your car is, and your use fo... May 27 2010, 10:33 PM
stewteral
Depending how extreme your car is, and your use f... May 27 2010, 11:03 PM
TorqueJunkie Thanks for the input. The willwood set-up looks n... May 28 2010, 05:32 AM
J P Stein "Upgrade" in regard to 914 brakes is ba... May 28 2010, 09:16 AM
brant I think you just need to buy the proper pads
I dou... May 30 2010, 08:42 PM
Eric_Shea Go watch an HSR 2 Litre Challenge event. If you... May 30 2010, 11:51 PM
ArtechnikA For a good (did not say cheap) street/AX pad, go g... May 31 2010, 06:35 AM
TorqueJunkie I am going to keep my Alloy S calipers for now and... Jun 4 2010, 08:32 PM
J P Stein A good addition to S calipers is a set of Stainles... Jun 5 2010, 05:56 AM
brant and I've had good luck with the Pagid 4S stree... Jun 5 2010, 07:38 AM
TorqueJunkie I have stainless pistons in them. Car sat out and... Jun 5 2010, 08:22 PM
J P Stein
I have stainless pistons in them. Car sat out an... Jun 6 2010, 08:04 AM
brant I think you will find that the modern carbon pads ... Jun 6 2010, 08:57 AM
naro914 just to add to this, I have 993 rear calipers on t... Jun 7 2010, 07:19 PM
naro914 OK, i just looked at this picture and realized I a... Jun 7 2010, 07:25 PM
andys
OK, i just looked at this picture and realized I ... Jun 8 2010, 09:15 AM
naro914 23 mm. Jun 8 2010, 09:22 AM
naro914 Huey should be back at the shop next week or so to... Jun 8 2010, 01:49 PM
Steve I'm running Boxster calipers front and rear. ... Jun 14 2010, 09:06 AM
MikeSpraggi Building my track car now. I am using 951 front ca... Jun 16 2010, 04:39 AM
rickthejetman
Building my track car now. I am using 951 front c... Jun 16 2010, 05:35 PM
MikeSpraggi
Building my track car now. I am using 951 front ... Jul 2 2010, 04:36 AM
brant I know vintage racing out here requires the brakes... Jul 2 2010, 09:51 AM
MikeSpraggi Brant, I know what you are saying about the origin... Jul 2 2010, 10:36 AM
brant
Brant, I know what you are saying about the origi... Jul 4 2010, 07:38 AM
Randal I agree with JP that the original poster doesn... Jul 4 2010, 11:46 AM
Eric_Shea Carrera calipers are the heaviest calipers ever ma... Jul 8 2010, 04:00 PM
J P Stein
Carrera calipers are the heaviest calipers ever m... Jul 8 2010, 05:45 PM
ArtechnikA
You're right, Eric, but I had no luck with 91... Jul 8 2010, 05:50 PM
Eric_Shea
:agree: Probably saved a little weight with tha... Jul 12 2010, 08:58 AM
J P Stein It came dow to time, money, & effort.I knew th... Jul 12 2010, 10:38 AM
jt914-6 OK..there are lots of brake "upgrades" t... Sep 4 2010, 06:54 PM
TorqueJunkie Well I finally got my brakes off and rebuilt. All... Feb 19 2011, 11:06 PM![]() ![]() |
Lo-Fi Version | Time is now: 9th January 2026 - 03:13 AM |
