Idle starts jumping around, After 1 or 2 minutes of running |
championgt1 |
May 28 2010, 10:59 PM
Don't embarrass me Filmore! Group: Members Posts: 2,680 Joined: 3-January 07 From: Tacoma, Washington Member No.: 7,420 Region Association: Pacific Northwest |
Car is a 74 djet. When I first start it cold it idles steady at around 1200rpm. After a minute or two it starts to jump back and forth from around 500rpm to 1200rpm or so. Any suggestions on what to look for? CHT? AAR?
detoxcowboy |
May 29 2010, 06:44 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
Car is a 74 djet. When I first start it cold it idles steady at around 1200rpm. After a minute or two it starts to jump back and forth from around 500rpm to 1200rpm or so. Any suggestions on what to look for? CHT? AAR? i would check the AAR and its adjacent hoses, if its a cht issue it may really be an ecu issue and or as well.. the wierdness of it and that it happens in only 1 or 2 minutes (IMG:style_emoticons/default/confused24.gif) usually ARR leak makes high idle, PVC valve issue?? sounds like it is going lean on the mixturte after 2 minutes ect.. below is copied from the ecu doc. link: http://members.rennlist.com/pbanders/idle.htm My idle is rough and surges when it's warming up Lean idle mixture during warm-up. According Brad Mayeur, a 914 expert, who worked on these cars in the '70's at a Porsche dealership, poor running during warm-up due to lean mixture was a common problem on the 2.0L engines, not as common on the 1.7L's. The factory "fix" for this problem was to install a spacer between the CHT and the head. The spacer delayed the CHT's response to the changes in head temp, causing the ECU to deliver a richer mixture. I had this problem, and first made my own spacer, then got a very nice replica spacer from Brad, which totally fixed my warm-up issues. Locate Brad using Google if you're interested in getting a spacer. |
Lo-Fi Version | Time is now: 1st June 2024 - 12:36 PM |
