| type2man |
May 25 2010, 02:12 PM
Member ![]() ![]() Group: Members Posts: 355 Joined: 3-March 09 From: Miami, Fl Member No.: 10,127 Region Association: South East States |
So the other day I decided to take my 914 out for a drive. About 20 mins. into the drive, the alternator light came on so I stopped and checked the belt and it was there. Started it back up and drove it home. On the way home, anytime I would press the brake pedal, the temp gauge and fuel gauge would drop to zero.
Drove for another 20 mins. until I got home. Turned it off, and when I turned the ignition back on, neither the oil or the generator light would come on, but the car would start right up. So I shut it off and when I got out of the car I noticed the right front turn signal, marker light and tailamp were on. So I disconnected the battery and that's where I am at. Anytime I hook the battery up, the right lights come on. The car starts but the oil and alt. light will not come on. Any ideas of where to start looking? Any advice would be appreciated. Thanks, Patrick |
| type2man |
May 30 2010, 12:31 PM
Update:
I found the voltage was 12.4 before and after starting the car. So I swapped out the voltage regulator from my parts car onto it. Now I am getting 13.8 volts with the car running. I still get no alt/oil light coming on and the battery gauge in the center console always reads zero. The wipers are working. But now the alternator light is backwards. When I fisrt start the car it's not on and I get 12.4 volts but when I rev it a little the light comes on and the fuel gauge goes up to its normal setting and I get 13.8 volts. Weird. I also tightened the bolt under the left tray area. By the way, it's a 74 2.0 with dual carbs and the battery, clock and temp gauges in the center console. Any other ideas would be great. |
type2man Electrical gremlin help needed May 25 2010, 02:12 PM
realred914
So the other day I decided to take my 914 out for... May 25 2010, 02:26 PM
underthetire Look for the fuse you kicked out getting in/out of... May 25 2010, 02:56 PM
type2man
Look for the fuse you kicked out getting in/out o... May 25 2010, 04:08 PM
type2man Update, I got the turn signal lever centered. It w... May 25 2010, 05:08 PM
ClayPerrine It is probably the power feed to the gauges. It c... May 25 2010, 08:12 PM
Spoke Do you have a voltmeter? If not, buy one, you... May 25 2010, 08:29 PM
Tom Check the ground post on the inner fender near the... May 26 2010, 09:48 AM
brp986s I had the symptoms you describe at one time. If I... May 30 2010, 05:23 PM![]() ![]() |
Lo-Fi Version | Time is now: 25th June 2026 - 06:22 AM |
