| ruddyboys |
Jun 1 2010, 08:20 AM
Hummel eigentümer ![]() ![]() ![]() Group: Members Posts: 595 Joined: 3-March 04 From: Monroe, NY Member No.: 1,749 Region Association: North East States |
Not being a electrician I have a question.
Our companies "handyman" set up some outlets in the new photo studio. As soon as I plugged in my photo lights they would not go on, it seems they Both shorted out at the same time??????? I took my multi-tester to check the outlets. I get 119v from the large slot (neutral) to the small slot (power), also 119 from the small slot (Power) to the u shaped ground, But I also get 119V from the large slot (neutral) to the ground? I know believe neutral to ground should give me no voltage, am I correct. |
| ruddyboys |
Jun 1 2010, 10:34 AM
When I put the multi-tester on the Long Slot (negative) and the short slot I get 120, Short slot to ground 120, long slot to ground 120.
ruddyboys OT, Electrical question Jun 1 2010, 08:20 AM
underthetire Neutral and ground are tied together at the panel.... Jun 1 2010, 08:24 AM
ruddyboys Thats what I thought, thanks for the confirmation. Jun 1 2010, 08:37 AM
76-914 Just curious; what'd ya get across the hot and... Jun 1 2010, 10:11 AM
vsg914 You should get power only between the hot and nuet... Jun 1 2010, 10:43 AM
Tom_T Sounds like you got the same cross-eyed & lazy... Jun 1 2010, 05:25 PM
kg6dxn Unplug every thing on that circuit and test again.... Jun 1 2010, 05:46 PM
Zardozz Ya... something's fishy. Jun 1 2010, 05:51 PM![]() ![]() |
Lo-Fi Version | Time is now: 21st June 2026 - 12:56 AM |
