occational "clunk" sound, from the front of the car. |
VaccaRabite |
May 31 2010, 07:09 PM
En Garde! Group: Admin Posts: 13,456 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
So, I am driving down the road, and I get an occasional "clunk" sound. It feels and sounds like it is in the forward section of the car. Sometimes it will happen on a turn, sometimes under braking, and sometimes on small bumps.
I jacked the front end of the car up today, and gave the front wheels the shake and spin test. Its not wheel bearings. Everything is very firm, and the wheels turn freely. I have not looked for loose bolts yet, and might do that tomorrow. Any ideas on what it might be? Zach |
kenshapiro2002 |
Jun 2 2010, 01:54 PM
Senior Member Group: Members Posts: 1,441 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
Mine was sway bar bushings. BTW...how do you change out the shock absorber without taking out the strut (Vacca's last picture)?
Spoke |
Jun 2 2010, 02:25 PM
Jerry Group: Members Posts: 6,989 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None |
Mine was sway bar bushings. BTW...how do you change out the shock absorber without taking out the strut (Vacca's last picture)? Remove the top nut, compress the shock and pull it out like his is shown. It doesn't look like he even took the tire off. Not sure if he disconnected the tie rod. |
SirAndy |
Jun 2 2010, 02:42 PM
Resident German Group: Admin Posts: 41,669 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Remove the top nut, compress the shock and pull it out like his is shown. It doesn't look like he even took the tire off. Not sure if he disconnected the tie rod. No need to disconnect the tie rod. If you have a front sway bar, you might have to disconnect the drop-link to get the wheel to drop down enough. (IMG:style_emoticons/default/popcorn[1].gif) Andy |
kenshapiro2002 |
Jun 2 2010, 03:18 PM
SWEET! (IMG:style_emoticons/default/aktion035.gif)
jt914-6 |
Jun 2 2010, 06:03 PM
Driving & working on teeners 41 years Group: Members Posts: 1,786 Joined: 3-May 08 From: Bryant, Arkansas Member No.: 9,003 Region Association: South East States |
SWEET! (IMG:style_emoticons/default/aktion035.gif) Remove the top nut, compress the shock and pull it out like his is shown. It doesn't look like he even took the tire off. Not sure if he disconnected the tie rod. No need to disconnect the tie rod. If you have a front sway bar, you might have to disconnect the drop-link to get the wheel to drop down enough. ---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------- Ken....when you do that....watch the flexable brake line and don't pull it too tight when getting shock facing out of the wheel well..... (IMG:style_emoticons/default/smash.gif) |
Lo-Fi Version | Time is now: 2nd June 2024 - 07:32 AM |
