Fuel line Question, Replace hard line in tunnel with soft??? |
kfish914 |
Jun 3 2010, 09:32 AM
Member Group: Members Posts: 161 Joined: 7-May 08 From: Osceola, Indiana Member No.: 9,026 Region Association: Upper MidWest |
I know I may get a lashing for asking this but with a budget in mind. Would there be any issues with replacing the hard plastic lines with rubber lines? I know I could use electrician's fish tape to pull it through into place. My worries are the grommet area (where the hose would pass through the body panels) rubbing or kinking the fuel line. I am exchanging the current 1.8 four, for a 2.7 six.
Any thoughts? |
tod914 |
Jun 3 2010, 06:19 PM
Advanced Member Group: Members Posts: 3,755 Joined: 19-January 03 From: Lincoln Park, NJ Member No.: 170 |
If you want to do it inexpensively and have piece of mind, you can goto your flaps and pick up a 60" length of flexable steel brake line and use a pipe cutter to take off the ends. File it down and flare it if you want. The 60" length works perfect. You'll need to bend/arc the lines abit inside the gas tank area with a tube bender. Easy enough to do once you run the lines through the tunnel. The line should be $5.00 each or so.
Lo-Fi Version | Time is now: 10th June 2024 - 05:47 AM |
