> rebuilt engine knocking?, engine builder says its normal for big bore 4's?
narino
post Jun 5 2010, 06:04 PM
Alright I understand these cars don't have the quietest, smoothest runnning engines made, but does this doesn't sound right to me. There is a knocking sound at startup until she's warmed up. Then it smooths out, not completely though still can hear the knock.
The engine builder, who builds racing type IV engines says that the noise is typical with big bore type IV engines. Here is a link to a video, what do you guys think?
video
http://www.narino.com/images/914-knocking.wmv
Here is what the engine currently has inside it: (originally a 1.7)
103 mm x 78 Stroke
2.0 H beam 5.325 (? no idea what this is was on the paper)
G - Cam
44 x 38 Heads
Thanks in advance!
(IMG:style_emoticons/default/beer.gif)
jmill
post Jun 6 2010, 11:11 AM
Green Hornet
From your explaination I figured it was just noise from solid lifters. That's not the case from your clip. I'm hoping Jake pops in and takes a listen. He'll know for sure. I can tell you I'd be worried too. That sounds like piston or rod noise. Something isn't right.
narino   rebuilt engine knocking?   Jun 5 2010, 06:04 PM
Lennies914   If I were the builder I would want to see and hear...   Jun 5 2010, 08:37 PM
kg6dxn   does not sound right to me. I think he did not cle...   Jun 5 2010, 09:26 PM
hot_shoe914   does not sound right to me. I think he did not cl...   Jun 5 2010, 09:58 PM
charliew   Either that or just rev it up and hold it it at ab...   Jun 5 2010, 09:42 PM
kg6dxn   Either that or just rev it up and hold it it at a...   Jun 5 2010, 09:50 PM
SLITS   Why don't you ask how much clearance was used ...   Jun 5 2010, 10:19 PM
McMark   Also what deck height. I've seen an engine th...   Jun 5 2010, 10:25 PM
aircooledtechguy   Also what deck height. I've seen an engine t...   Jun 6 2010, 12:47 PM
Brodie   Doesn't sound good to me. Could be piston sla...   Jun 6 2010, 10:55 AM
jmill   From your explaination I figured it was just noise...   Jun 6 2010, 11:11 AM
sean_v8_914   is it cold? hot? change intensity with increaese i...   Jun 6 2010, 01:27 PM
narino   Thanks for the help guys. Mike - I'm going to...   Jun 6 2010, 02:04 PM
kg6dxn   If it is deck clearance you can shim the bottom of...   Jun 6 2010, 04:32 PM
Jake Raby   Sounds like the builder used a forged piston set w...   Jun 6 2010, 06:03 PM
Eddie914   I have owned a number of 1988 BMW M5's. The S3...   Jun 6 2010, 07:52 PM
tornik550   Sounds like the rocker arms are hitting the valve ...   Jun 6 2010, 08:04 PM
detoxcowboy   Sounds like the rocker arms are hitting the valve...   Jun 7 2010, 08:51 AM
Jake Raby   If the valve covers were seeing contact from the r...   Jun 6 2010, 08:23 PM
Cap'n Krusty   Who is the rebuilder? The Cap'n   Jun 7 2010, 08:44 AM
sean_v8_914   I dont think my 103s are that loud...maybe Im used...   Jun 7 2010, 10:27 AM
Jake Raby   Yes, the stroke changes the rod angle, which can i...   Jun 7 2010, 10:41 AM
narino   Just talked to the builder and he was more than ha...   Jun 7 2010, 11:29 AM
Jake Raby   Good for you to wait till see how things work out ...   Jun 7 2010, 12:26 PM
narino   Ok bringing this one back. After paying off some c...   Jan 5 2011, 07:21 PM
rick 918-S   Ok bringing this one back. After paying off some ...   Jan 5 2011, 09:05 PM
karlo   Forging eliminates metal porosity and improves duc...   Jan 6 2011, 01:47 AM
Vacca Rabite   $650 is probably a deal to have the work done...   Jan 6 2011, 08:33 AM
Root_Werks   $650 is probably a deal to have the work don...   Jan 6 2011, 09:47 AM
narino   Again, thank you guys for your replies. Vacca/Roo...   Jan 6 2011, 12:58 PM
Vacca Rabite   I guess after the swap to cast pistons could I e...   Jan 6 2011, 01:55 PM
realred914   if it is too much noise for you ask to hear one of...   Jan 6 2011, 02:15 PM
narino   Builder says as long as the piston all weigh the s...   Jan 6 2011, 02:30 PM
- Lo-Fi Version Time is now: 17th April 2026 - 05:27 AM
