> Brake warning light, Light won't stop flashing with engine running
jsaum
post Jun 6 2010, 09:23 PM
The warning light on my 72 is staying on after the engine is started. I don't have a owners manual so I don't exactly know how the two red lights at the top of the fuel gauge normally operate. Months ago after I got the engine back in the car it went out the first couple of times I started the car. Now if flashes all of the time. I believe it will normally flash until the engine is started then will go out. I did reuild all of my calipers and installed a new 911 master cylinder. After bleeding the system repeated times I now have a some what firm pedal but it still seems like it's not quite right. I pulled the cover and checked the pressure switch and it is working the switch is made allowing a signal to pass through. I read some of the threads and there is mention of a reset button on the master cylinder but I don't think the 72 has it. I'm using the two lead switch. I also checked the e brake switch is is working correctly after I release the parking brake the fasten seat belt light will come on if the sealt belt isn't fastened. Has anyone had this problem before? What am I missing?
Thanks for the help!
Jsaum
- Lo-Fi Version Time is now: 15th July 2025 - 11:51 AM
