> Brake upgrades? What do you use?
TorqueJunkie
post May 27 2010, 08:34 PM
I have a 1973 914/6 conversion with 2.4 L engine(being rebuilt now), and I am running the Alloy "S" brake calipers up front. I am looking to upgrade the front brakes. Boxster calipers are cheaper than the Big reds and a bit smaller as I would like to run a 17" wheel or smaller.
Anyone have the boxster calipers installed? Which rotors did you use? Adapters?
I have an old set of Bremtek calipers that I might use if I can find some seal kits for them still.
New to these forums, but love all the stuff on this site...especially all the racing pics
naro914
post Jun 7 2010, 07:25 PM
Losing my mind...
OK, i just looked at this picture and realized I also have completely different suspension and spindles, so this isn't applicable for most.
The 993 rear calipers will ALMOST fit onto 3.5" stock spindles - that's what Huey has. You have to wallow out the caliper holes a couple mm to the inside, but they fit perfect on the rotor. I've run them on Huey for street, AX, and Targa Newfoundland for 4 years, and on Papa Smurf for at least 6 years.
andys
post Jun 8 2010, 09:15 AM
QUOTE(naro914 @ Jun 7 2010, 06:25 PM) *
Bob,
What size master cylinder are you using with your setup?
Andys
TorqueJunkie   Brake upgrades? What do you use?   May 27 2010, 08:34 PM
stewteral   I have a 1973 914/6 conversion with 2.4 L engine(...   May 27 2010, 09:26 PM
camaroz1985   Hey Torque Junkie, For my $$, you can...   May 28 2010, 07:50 AM
stewteral   [quote name='stewteral' post='1324728' date='May ...   May 28 2010, 10:45 AM
rickthejetman   I have a 1973 914/6 conversion with 2.4 L engine...   May 30 2010, 06:18 PM
stewteral   [quote name='stewteral' post='1324728' date='May ...   May 30 2010, 11:19 PM
campbellcj   Depending how extreme your car is, and your use fo...   May 27 2010, 10:33 PM
stewteral   Depending how extreme your car is, and your use f...   May 27 2010, 11:03 PM
TorqueJunkie   Thanks for the input. The willwood set-up looks n...   May 28 2010, 05:32 AM
J P Stein   "Upgrade" in regard to 914 brakes is ba...   May 28 2010, 09:16 AM
brant   I think you just need to buy the proper pads I dou...   May 30 2010, 08:42 PM
Eric_Shea   Go watch an HSR 2 Litre Challenge event. If you...   May 30 2010, 11:51 PM
ArtechnikA   For a good (did not say cheap) street/AX pad, go g...   May 31 2010, 06:35 AM
TorqueJunkie   I am going to keep my Alloy S calipers for now and...   Jun 4 2010, 08:32 PM
J P Stein   A good addition to S calipers is a set of Stainles...   Jun 5 2010, 05:56 AM
brant   and I've had good luck with the Pagid 4S stree...   Jun 5 2010, 07:38 AM
TorqueJunkie   I have stainless pistons in them. Car sat out and...   Jun 5 2010, 08:22 PM
J P Stein   I have stainless pistons in them. Car sat out an...   Jun 6 2010, 08:04 AM
brant   I think you will find that the modern carbon pads ...   Jun 6 2010, 08:57 AM
naro914   just to add to this, I have 993 rear calipers on t...   Jun 7 2010, 07:19 PM
naro914   OK, i just looked at this picture and realized I a...   Jun 7 2010, 07:25 PM
andys   OK, i just looked at this picture and realized I ...   Jun 8 2010, 09:15 AM
naro914   23 mm.   Jun 8 2010, 09:22 AM
naro914   Huey should be back at the shop next week or so to...   Jun 8 2010, 01:49 PM
Steve   I'm running Boxster calipers front and rear. ...   Jun 14 2010, 09:06 AM
MikeSpraggi   Building my track car now. I am using 951 front ca...   Jun 16 2010, 04:39 AM
rickthejetman   Building my track car now. I am using 951 front c...   Jun 16 2010, 05:35 PM
MikeSpraggi   Building my track car now. I am using 951 front ...   Jul 2 2010, 04:36 AM
brant   I know vintage racing out here requires the brakes...   Jul 2 2010, 09:51 AM
MikeSpraggi   Brant, I know what you are saying about the origin...   Jul 2 2010, 10:36 AM
brant   Brant, I know what you are saying about the origi...   Jul 4 2010, 07:38 AM
Randal   I agree with JP that the original poster doesn...   Jul 4 2010, 11:46 AM
Eric_Shea   Carrera calipers are the heaviest calipers ever ma...   Jul 8 2010, 04:00 PM
J P Stein   Carrera calipers are the heaviest calipers ever m...   Jul 8 2010, 05:45 PM
ArtechnikA   You're right, Eric, but I had no luck with 91...   Jul 8 2010, 05:50 PM
Eric_Shea   :agree: Probably saved a little weight with tha...   Jul 12 2010, 08:58 AM
J P Stein   It came dow to time, money, & effort.I knew th...   Jul 12 2010, 10:38 AM
jt914-6   OK..there are lots of brake "upgrades" t...   Sep 4 2010, 06:54 PM
TorqueJunkie   Well I finally got my brakes off and rebuilt. All...   Feb 19 2011, 11:06 PM
- Lo-Fi Version Time is now: 9th January 2026 - 03:13 AM
