> Model Specific Information
> Gas tank resto, Final Phase - Tank
Pat Garvey
post May 15 2010, 08:27 PM
Do I or don't I...........?
As many of you know, I have a tank problem, from fibe years (almost) gas sitting in the tank. I bought a good tank, with a bad finish. I'm documenting the rstor of it here.
Phase One - the easy part. I used the evap tank to rehone my finishing skills. It was presentable to most, but not to me. Stripped to bare metal, primed, wet sanded & 3 final coats of black satin. Three days later - wet sanded with 800 grit, Turtle Wax rubbing compound, and Meguiars Show car Glaze. Too shiney, but blame it on intense wet sanding!
Pics show it all.
Pat
Phase Two - Fuel collar. Not too bad after some high grit sanding. We'll see how tha finish coat sticks. Stay tuned, because the tank comes next!
For those who think I'm sitting on my ass, pontificating - think again!
Pat
Tom_T
post May 15 2010, 11:18 PM
TMI....
Pat - what was the red primer you used (name/brand) & where do you get it?
Keep up the posts as the project progresses plz!
Pat Garvey
post May 16 2010, 06:41 PM
QUOTE(Tom_T @ May 15 2010, 11:18 PM) *
Tom,
It's Krylon. Yeah, I know that many people thru the years have poo-poo'd it as "non-professional". Fact is this - I've used Krylon products successfully for years. It's all in the preparation, and the tasks between coats.
When I first started on this evaporator, I though about just simply taking it down to bare metal with finer & finer grits. I have a Craftsman triple head sander that I use because it moves around corners nicely. But first I used a product called Citrus Strip - you can get it at any FLAPS & comes in brush-on or spray version. I've used the spray version a bunch of times & prefer it because it doesn't leave a mess behind. Spray it on, wait 12-24 hours & the paint amost slides off usually. In this case it didn't get everything, so I brought the sander into play. As you can see, that was the end of the rest of the paint, though I did take the metal down to 800 grit.
Next, I wiped everything down with laquer thinner. Opened all doors & ran like hell,even though I wore protection. Didn't smoke my pipe that afternoon!
Next came the Rustoleum Rust Tough. It's formulated so that it checks rust, so long as you've scraped any chunks of rust off. I didn't want o take a chance with that, which is why I sanded. Two coats, let dry for 36-48 hrs. Wet sand & let dry. Smooth as a babies bottom & ready to topcoat. Recommend this product.
Pat
Pat Garvey
post Jun 8 2010, 06:35 PM
QUOTE(Pat Garvey @ May 16 2010, 06:41 PM) *
Tom,
It's Rustoleum. Yeah, I know that many people thru the years have poo-poo'd it as "non-professional". Fact is this - I've used Rusto products successfully for years. It's all in the preparation, and the tasks between coats.
Pat
Whoops! Forgot that I changed medium. Not Rustoleun - Krylon!
Pat
Pat Garvey   Gas tank resto   May 15 2010, 08:27 PM
Tom_T   Pat - what was the red primer you used (name/brand...   May 15 2010, 11:18 PM
Pat Garvey   Pat - what was the red primer you used (name/bran...   May 16 2010, 06:41 PM
Pat Garvey   Pat - what was the red primer you used (name/bra...   Jun 8 2010, 06:35 PM
tod914   Pat looks real nice. I used the Mequires too. De...   May 16 2010, 05:35 PM
Pat Garvey   Pat looks real nice. I used the Mequires too. D...   May 16 2010, 06:49 PM
Tom_T   Thanx for the step-by-step Pat! I'll hav...   May 17 2010, 12:38 AM
Pat Garvey   So, the collar is now done. Came ou pretty nice - ...   May 20 2010, 06:49 PM
Tom_T   So, the collar is now done. Came ou pretty nice -...   May 21 2010, 12:36 AM
Pat Garvey   So, the collar is now done. Came ou pretty nice ...   May 21 2010, 06:06 PM
Tom_T   What! Works in hillbillyland! Careful ...   May 21 2010, 06:22 PM
kharma   Watching with great interest... redoing all the fu...   May 21 2010, 06:26 AM
Pat Garvey   Watching with great interest... redoing all the f...   May 21 2010, 06:11 PM
tod914   A jig to paint the tank Pat? I layed mine on a la...   May 21 2010, 09:20 AM
Pat Garvey   A jig to paint the tank Pat? I layed mine on a l...   May 21 2010, 06:03 PM
tod914   Pat your more meticulous than I thought! Now ...   May 21 2010, 07:03 PM
Pat Garvey   Well, I started sanding the tank today. Initially...   May 22 2010, 04:08 PM
MrKona   2. I'll be straying from my usual paint cho...   May 23 2010, 11:18 PM
Pat Garvey   2. I'll be straying from my usual paint ch...   May 27 2010, 06:37 PM
Tom_T   Pat, the problem you need to assess is whether the...   May 23 2010, 08:19 PM
scotty b   No need to go to bare metal unless there is rust s...   Jun 2 2010, 07:28 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 8 2010, 06:46 PM
Pat Garvey   Update(and I know most of you think I'm freaki...   Jun 2 2010, 07:38 PM
avidfanjpl   Hey Pat, I knew I should have put up info on my t...   Jun 2 2010, 11:59 PM
Pat Garvey   Hey Pat, I knew I should have put up info on my ...   Jun 3 2010, 08:45 PM
tod914   John, I like some of the POR products too. After ...   Jun 4 2010, 12:05 AM
Pat Garvey   John, I like some of the POR products too. After...   Jun 6 2010, 06:03 PM
avidfanjpl   Hey Pat and Tod, You guys are WAY ahead on things...   Jun 4 2010, 12:31 AM
tod914   Cool deal John. When did you move out of NJ?   Jun 6 2010, 10:22 AM
scotty b   You do realize that the gas tanks were never finis...   Jun 13 2010, 02:13 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 13 2010, 06:43 PM
tod914   Scotty, I think Pat was going to add the factory r...   Jun 13 2010, 02:16 PM
scotty b   I should have known your nipples were perfect Pat ...   Jun 13 2010, 07:08 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 14 2010, 06:08 PM
Pat Garvey   OK, now I need some help! I primed the tank w...   Jun 15 2010, 08:03 PM
Tom_T   OK, now I need some help! I primed the tank ...   Jun 15 2010, 11:12 PM
Pat Garvey   OK, now I need some help! I primed the tank...   Jun 16 2010, 08:09 PM
Tom_T   [quote name='Tom_T' post='1331290' date='Jun 15 2...   Jun 16 2010, 10:38 PM
Jasfsmith   I know that most of think I'm whacko, but I ...   Jun 16 2010, 07:51 AM
Pat Garvey   I know that most of think I'm whacko, but I...   Jun 16 2010, 07:51 PM
tod914   That's too funny Scotty. Do you think Pat wax...   Jun 15 2010, 08:38 PM
Jon Fernandes   Pat, steel wool may leave scratches in the primer....   Jun 15 2010, 08:53 PM
Pat Garvey   Ok, here's where I am today. The zinc-rich pr...   Jun 18 2010, 04:17 PM
tod914   Think your looking for BusDepot.com. WolfsburgWes...   Jun 19 2010, 09:40 AM
Tom_T   Think your looking for BusDepot.com. WolfsburgWe...   Jun 19 2010, 02:54 PM
Pat Garvey   Think your looking for BusDepot.com. WolfsburgW...   Jun 19 2010, 04:48 PM
Pat Garvey   Well, I now have 3 coats of L43 on the front half ...   Jun 22 2010, 07:23 PM
Tom_T   Well, I now have 3 coats of L43 on the front half...   Jun 22 2010, 07:39 PM
tod914   Wow not grey enough? I'm very surprized to he...   Jun 23 2010, 08:29 AM
Pat Garvey   Wow not grey enough? I'm very surprized to h...   Jun 25 2010, 06:47 PM
Niklas   Hi! Why are you not using powdercoating ? In ...   Jun 23 2010, 10:23 AM
Pat Garvey   Hi! Why are you not using powdercoating ? In...   Jun 25 2010, 06:41 PM
Cairo94507   Man, are we ever going to see this gas tank? Let...   Jun 25 2010, 08:41 PM
Pat Garvey   Man, are we ever going to see this gas tank? Let...   Jun 27 2010, 06:55 PM
tod914   I went through the same thing with my intake runne...   Jun 25 2010, 11:19 PM
Pat Garvey   I went through the same thing with my intake runn...   Jun 29 2010, 07:43 PM
Cairo94507   :popcorn:   Jun 28 2010, 07:14 PM
tod914   Pat I think it has too much green too it. Let me ...   Jun 29 2010, 09:38 PM
Pat Garvey   Well, I went through several days of 95-105 temps ...   Jul 9 2010, 04:49 PM
Tom_T   So why aren't those chrome wheels on Fritz? T...   Jul 9 2010, 05:06 PM
Pat Garvey   So why aren't those chrome wheels on Fritz? ...   Jul 9 2010, 06:19 PM
Tom_T   You do it & do it right, or redo it! I ...   Jul 9 2010, 09:01 PM
Pat Garvey   You do it & do it right, or redo it! I...   Jul 12 2010, 08:00 PM
Pat Garvey   Refinishing complete! Jeez! All it needs ...   Jul 13 2010, 07:43 PM
Pat Garvey   Refinishing complete! Jeez! All it needs...   Jul 14 2010, 07:49 PM
Tom_T   Well Pat - it looks great on its own, but I can de...   Jul 13 2010, 07:50 PM
Pat Garvey   Well Pat - it looks great on its own, but I can d...   Jul 14 2010, 07:41 PM
Tom_T   [quote name='Tom_T' post='1343215' date='Jul 13 2...   Jul 15 2010, 10:36 AM
Pat Garvey   [quote name='Tom_T' post='1343215' date='Jul 13 ...   Jul 16 2010, 05:46 PM
scotty b   :blink: your gas tank looks better than most peopl...   Jul 14 2010, 02:18 PM
Pat Garvey   :blink: your gas tank looks better than most peop...   Jul 14 2010, 07:32 PM
tod914   Very nice Pat. Tank appears flawless. Drop it in...   Jul 14 2010, 05:58 PM
Tom_T   Very nice Pat. Tank appears flawless. Drop it i...   Jul 14 2010, 06:16 PM
Tom_T   Pat - I just meant that in my 73 914-2.0's tan...   Jul 16 2010, 06:12 PM
Pat Garvey   Pat - I just meant that in my 73 914-2.0's ta...   Jul 16 2010, 06:31 PM
Tom_T   Thanx Pat - I've had many surprises so far - s...   Jul 16 2010, 06:36 PM
Pat Garvey   Thanx Pat - I've had many surprises so far - ...   Jul 16 2010, 07:33 PM
Tom_T   Thanx Pat - I've had many surprises so far -...   Jul 16 2010, 07:41 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:28 AM
