> Brake upgrades? What do you use?
TorqueJunkie
post May 27 2010, 08:34 PM
I have a 1973 914/6 conversion with 2.4 L engine(being rebuilt now), and I am running the Alloy "S" brake calipers up front. I am looking to upgrade the front brakes. Boxster calipers are cheaper than the Big reds and a bit smaller as I would like to run a 17" wheel or smaller.
Anyone have the boxster calipers installed? Which rotors did you use? Adapters?
I have an old set of Bremtek calipers that I might use if I can find some seal kits for them still.
New to these forums, but love all the stuff on this site...especially all the racing pics
Steve
post Jun 14 2010, 09:06 AM
I'm running Boxster calipers front and rear. Very happy with the setup. No squeaks or squeals and great breaking!! Up front i'm running 3.5" struts with standard 911 ventilated disks. In the rear early ventilated 911 disks. Adapters front and rear are from Richard Johnson. I'm also running a 911 emergency brake. I'm also running a 19mm master cylinder. Seems fine to me, but I have never tried a bigger one.
TorqueJunkie   Brake upgrades? What do you use?   May 27 2010, 08:34 PM
stewteral   I have a 1973 914/6 conversion with 2.4 L engine(...   May 27 2010, 09:26 PM
camaroz1985   Hey Torque Junkie, For my $$, you can...   May 28 2010, 07:50 AM
stewteral   [quote name='stewteral' post='1324728' date='May ...   May 28 2010, 10:45 AM
rickthejetman   I have a 1973 914/6 conversion with 2.4 L engine...   May 30 2010, 06:18 PM
stewteral   [quote name='stewteral' post='1324728' date='May ...   May 30 2010, 11:19 PM
campbellcj   Depending how extreme your car is, and your use fo...   May 27 2010, 10:33 PM
stewteral   Depending how extreme your car is, and your use f...   May 27 2010, 11:03 PM
TorqueJunkie   Thanks for the input. The willwood set-up looks n...   May 28 2010, 05:32 AM
J P Stein   "Upgrade" in regard to 914 brakes is ba...   May 28 2010, 09:16 AM
brant   I think you just need to buy the proper pads I dou...   May 30 2010, 08:42 PM
Eric_Shea   Go watch an HSR 2 Litre Challenge event. If you...   May 30 2010, 11:51 PM
ArtechnikA   For a good (did not say cheap) street/AX pad, go g...   May 31 2010, 06:35 AM
TorqueJunkie   I am going to keep my Alloy S calipers for now and...   Jun 4 2010, 08:32 PM
J P Stein   A good addition to S calipers is a set of Stainles...   Jun 5 2010, 05:56 AM
brant   and I've had good luck with the Pagid 4S stree...   Jun 5 2010, 07:38 AM
TorqueJunkie   I have stainless pistons in them. Car sat out and...   Jun 5 2010, 08:22 PM
J P Stein   I have stainless pistons in them. Car sat out an...   Jun 6 2010, 08:04 AM
brant   I think you will find that the modern carbon pads ...   Jun 6 2010, 08:57 AM
naro914   just to add to this, I have 993 rear calipers on t...   Jun 7 2010, 07:19 PM
naro914   OK, i just looked at this picture and realized I a...   Jun 7 2010, 07:25 PM
andys   OK, i just looked at this picture and realized I ...   Jun 8 2010, 09:15 AM
naro914   23 mm.   Jun 8 2010, 09:22 AM
naro914   Huey should be back at the shop next week or so to...   Jun 8 2010, 01:49 PM
Steve   I'm running Boxster calipers front and rear. ...   Jun 14 2010, 09:06 AM
MikeSpraggi   Building my track car now. I am using 951 front ca...   Jun 16 2010, 04:39 AM
rickthejetman   Building my track car now. I am using 951 front c...   Jun 16 2010, 05:35 PM
MikeSpraggi   Building my track car now. I am using 951 front ...   Jul 2 2010, 04:36 AM
brant   I know vintage racing out here requires the brakes...   Jul 2 2010, 09:51 AM
MikeSpraggi   Brant, I know what you are saying about the origin...   Jul 2 2010, 10:36 AM
brant   Brant, I know what you are saying about the origi...   Jul 4 2010, 07:38 AM
Randal   I agree with JP that the original poster doesn...   Jul 4 2010, 11:46 AM
Eric_Shea   Carrera calipers are the heaviest calipers ever ma...   Jul 8 2010, 04:00 PM
J P Stein   Carrera calipers are the heaviest calipers ever m...   Jul 8 2010, 05:45 PM
ArtechnikA   You're right, Eric, but I had no luck with 91...   Jul 8 2010, 05:50 PM
Eric_Shea   :agree: Probably saved a little weight with tha...   Jul 12 2010, 08:58 AM
J P Stein   It came dow to time, money, & effort.I knew th...   Jul 12 2010, 10:38 AM
jt914-6   OK..there are lots of brake "upgrades" t...   Sep 4 2010, 06:54 PM
TorqueJunkie   Well I finally got my brakes off and rebuilt. All...   Feb 19 2011, 11:06 PM
- Lo-Fi Version Time is now: 9th January 2026 - 03:13 AM
