one warm, one alot warmer, intake manifords |
karmanbuilt |
Jun 14 2010, 09:42 PM
??? Group: Members Posts: 72 Joined: 7-July 08 From: Emmett, ID. Member No.: 9,262 Region Association: Pacific Northwest |
After installing dual 40's on a '76 2.0, and running the tall manifords. They were set up by Jake, and started up the first time....Semper Fi! Anyway, after a valve adjustment, tweaking the timing, and fine tuning the carbs, took the car out for a fifthteen mile run. Still need to tweak the carbs, but noticed the bank of 1 & 2 were just barely warm. Bank 3 & 4 were almost hot! Searched the oldies posts back to 2003, and found a thread on gaskets. I had installed my manifolds with the gaskets that Jake had sent with the set, but had to remove the manifolds to plug the holes on each side. Reinstalled the manifolds with the FI gaskets. My question...sorry this is so long....was I suppose to add paper gaskets w/the FI ones??
VaccaRabite |
Jun 15 2010, 06:16 AM
En Garde! Group: Admin Posts: 13,465 Joined: 15-December 03 From: Dallastown, PA Member No.: 1,435 Region Association: MidAtlantic Region |
No to the paper gaskets.
The FI gaskets you are talking about are the ones with the plastic spacer? Here is what I did. I took the manifolds, and polished the flange with 400 grit sandpaper on a thick glass window pane until it was totally flat. This took a little time, but as soon as you start you can clearly see all the imperfections in the "flat" of the flange. As to the hot and cold, are you sure that the 1/2 bank of carbs is firing? Did you do any adjustment before you started driving? Sounds to me like you are driving off the 3/4 bank. You have to get them gross adjusted before you start driving. once driving you should only need little tweaks. Zach |
Lo-Fi Version | Time is now: 9th June 2024 - 10:08 PM |
