Cooling system flaps, how are they supposed to be oriented? |
brandomc |
Jun 16 2010, 02:06 PM
Member Group: Members Posts: 113 Joined: 14-May 09 From: los angeles california Member No.: 10,363 Region Association: Southern California |
I just got my 2056 back from my engine builder, and now im trying to install all the sheet metal. The engine builder suggested that i wire open my cooling system so that it doesnt ever mess up and overheat my engine. My question is how should the flaps be oriented if i wire them open. Why do i even need these flaps if im not using the thermostat system? IF anyone has any pics of how they oriented their flaps, that would help alot. Thanks!! Hopefully back on the road soon!!
detoxcowboy |
Jun 16 2010, 02:33 PM
Senior Member Group: Members Posts: 1,294 Joined: 30-January 08 Member No.: 8,642 Region Association: Africa |
(IMG:style_emoticons/default/drunk.gif) If your tossing everything, you will want to tuck the passengers side cooling flap over the oil cooler, it slips under the tin that stops the flap from hitting it.. that would make permenant the fail safe cooling position from overheating.. this is common for people whom do not care about warming up but want to keep from overheating..
the wieght savings is nil... better just to lose 2 lbs. in your diet.. or drive without a helmut.. |
brandomc |
Jun 16 2010, 02:37 PM
(IMG:style_emoticons/default/drunk.gif) If your tossing everything, you will want to tuck the passengers side cooling flap over the oil cooler, it slips under the tin that stops the flap from hitting it.. that would make permenant the fail safe cooling position from overheating.. this is common for people whom do not care about warming up but want to keep from overheating.. Sorry, i dont quite understand what you are explaining. Are you saying remove the rod and the flap on the drivers side, but keep the other flap and wire it down over the oil cooler? |
Lo-Fi Version | Time is now: 11th June 2024 - 07:04 AM |
