> Model Specific Information
> Gas tank resto, Final Phase - Tank
Pat Garvey
post May 15 2010, 08:27 PM
Do I or don't I...........?
As many of you know, I have a tank problem, from fibe years (almost) gas sitting in the tank. I bought a good tank, with a bad finish. I'm documenting the rstor of it here.
Phase One - the easy part. I used the evap tank to rehone my finishing skills. It was presentable to most, but not to me. Stripped to bare metal, primed, wet sanded & 3 final coats of black satin. Three days later - wet sanded with 800 grit, Turtle Wax rubbing compound, and Meguiars Show car Glaze. Too shiney, but blame it on intense wet sanding!
Pics show it all.
Pat
Phase Two - Fuel collar. Not too bad after some high grit sanding. We'll see how tha finish coat sticks. Stay tuned, because the tank comes next!
For those who think I'm sitting on my ass, pontificating - think again!
Pat
Pat Garvey
post Jun 15 2010, 08:03 PM
OK, now I need some help!
I primed the tank with a zinc-based primer. Seemed like the right thing to do. Prior to priming, everything was wet sanded with 320 grit. Nice "baby's butt" finish. Yhen I primed (after wiping down with 96% Isoprop).
But.....now I have this "nubby" finish that needs to be way cut before final coats. Tried wet sanding with 600 - little effect. Don't want to cut through the primer. Any thoughts on steel wool? Just want to take the nubs off, without cutting through 2 coats of primer.
I know that most of think I'm whacko, but I want my 914 preservedexactly as I got it in 1972.
Pat
Tom_T
post Jun 15 2010, 11:12 PM
TMI....
QUOTE(Pat Garvey @ Jun 15 2010, 07:03 PM) *
Pat
Pat, if it was smooth before paint, then you either got some grit on the surface (dust, lint, steel wool "hairs", etc.), or else the spray droplets dried before hitting the surface & creating the rough surface. Either way you'll need to re-smooth it with stepped grits (320, 400, 600), then shoot it again.
Then when you reshoot it, take it in several light coats (I tend to be "the king of runs" & have to watch myself - you may be the opposite erring too far & getting dry paint "dust" by the time it reaches the surface) & be careful with your spray distance to surface, technique, etc. - as the way it lays down can vary with temp., humidity, distance (too far creates a paint dust), how much the rattle can nozzle is putting out & how fine/dense the mist is, how well mixed the paint it, if it's old (sitting in a warehouse or your garage), and other factors.
It might help to have a test surface handy each time to try out what works best at particular times of day/night that you shoot coats. The dehumidifier can have localized effects too, if you're close to it, causing the paint mist to dry too much before it reaches the surface.
Pat Garvey
post Jun 16 2010, 08:09 PM
QUOTE(Tom_T @ Jun 15 2010, 11:12 PM) *
Pat
Tom,
Figure it out. It was the zinc-based primer. Mini particles of zinc mixed into the primer. Wasn't "nubbs", but the mini particles of zinc standing on end. Tried ti take them down with 600 grit, but they were just bending.. Went back to 400 & it worked fine, though cut through in a couple of spots. Re-primed & will take them down with 1200, as well as the rest of the tank.
Then comes the L43. The gift can from Tod won't be nearly enough - I want 2 coats, 1500 grit wet sand & a final coat, so I'll need more L43.
Hint to others - if you use Krylon zinc based primer expect extra work. Is it worth it - dunno. We'll see.
Am I making this a lifetime event? You tell me when it's complete. Yes, I am anal!
Pat
Tom_T
post Jun 16 2010, 10:38 PM
TMI....
QUOTE(Pat Garvey @ Jun 16 2010, 07:09 PM) *
Pat
Tom,
Pat
Pat, the Wurth zinc rich primer seems to be smoother & work better.
Here's where I told Tod about the L43 -
http://www.wolfsburgwest.com/wolfsburg_new...stuff/paint.cfm
Pat Garvey   Gas tank resto   May 15 2010, 08:27 PM
Tom_T   Pat - what was the red primer you used (name/brand...   May 15 2010, 11:18 PM
Pat Garvey   Pat - what was the red primer you used (name/bran...   May 16 2010, 06:41 PM
Pat Garvey   Pat - what was the red primer you used (name/bra...   Jun 8 2010, 06:35 PM
tod914   Pat looks real nice. I used the Mequires too. De...   May 16 2010, 05:35 PM
Pat Garvey   Pat looks real nice. I used the Mequires too. D...   May 16 2010, 06:49 PM
Tom_T   Thanx for the step-by-step Pat! I'll hav...   May 17 2010, 12:38 AM
Pat Garvey   So, the collar is now done. Came ou pretty nice - ...   May 20 2010, 06:49 PM
Tom_T   So, the collar is now done. Came ou pretty nice -...   May 21 2010, 12:36 AM
Pat Garvey   So, the collar is now done. Came ou pretty nice ...   May 21 2010, 06:06 PM
Tom_T   What! Works in hillbillyland! Careful ...   May 21 2010, 06:22 PM
kharma   Watching with great interest... redoing all the fu...   May 21 2010, 06:26 AM
Pat Garvey   Watching with great interest... redoing all the f...   May 21 2010, 06:11 PM
tod914   A jig to paint the tank Pat? I layed mine on a la...   May 21 2010, 09:20 AM
Pat Garvey   A jig to paint the tank Pat? I layed mine on a l...   May 21 2010, 06:03 PM
tod914   Pat your more meticulous than I thought! Now ...   May 21 2010, 07:03 PM
Pat Garvey   Well, I started sanding the tank today. Initially...   May 22 2010, 04:08 PM
MrKona   2. I'll be straying from my usual paint cho...   May 23 2010, 11:18 PM
Pat Garvey   2. I'll be straying from my usual paint ch...   May 27 2010, 06:37 PM
Tom_T   Pat, the problem you need to assess is whether the...   May 23 2010, 08:19 PM
scotty b   No need to go to bare metal unless there is rust s...   Jun 2 2010, 07:28 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 8 2010, 06:46 PM
Pat Garvey   Update(and I know most of you think I'm freaki...   Jun 2 2010, 07:38 PM
avidfanjpl   Hey Pat, I knew I should have put up info on my t...   Jun 2 2010, 11:59 PM
Pat Garvey   Hey Pat, I knew I should have put up info on my ...   Jun 3 2010, 08:45 PM
tod914   John, I like some of the POR products too. After ...   Jun 4 2010, 12:05 AM
Pat Garvey   John, I like some of the POR products too. After...   Jun 6 2010, 06:03 PM
avidfanjpl   Hey Pat and Tod, You guys are WAY ahead on things...   Jun 4 2010, 12:31 AM
tod914   Cool deal John. When did you move out of NJ?   Jun 6 2010, 10:22 AM
scotty b   You do realize that the gas tanks were never finis...   Jun 13 2010, 02:13 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 13 2010, 06:43 PM
tod914   Scotty, I think Pat was going to add the factory r...   Jun 13 2010, 02:16 PM
scotty b   I should have known your nipples were perfect Pat ...   Jun 13 2010, 07:08 PM
Pat Garvey   B)-->
QUOTE(scotty b @ J...   Jun 14 2010, 06:08 PM
Jasfsmith   I know that most of think I'm whacko, but I ...   Jun 16 2010, 07:51 AM
Pat Garvey   I know that most of think I'm whacko, but I...   Jun 16 2010, 07:51 PM
tod914   That's too funny Scotty. Do you think Pat wax...   Jun 15 2010, 08:38 PM
Jon Fernandes   Pat, steel wool may leave scratches in the primer....   Jun 15 2010, 08:53 PM
Pat Garvey   Ok, here's where I am today. The zinc-rich pr...   Jun 18 2010, 04:17 PM
tod914   Think your looking for BusDepot.com. WolfsburgWes...   Jun 19 2010, 09:40 AM
Tom_T   Think your looking for BusDepot.com. WolfsburgWe...   Jun 19 2010, 02:54 PM
Pat Garvey   Think your looking for BusDepot.com. WolfsburgW...   Jun 19 2010, 04:48 PM
Pat Garvey   Well, I now have 3 coats of L43 on the front half ...   Jun 22 2010, 07:23 PM
Tom_T   Well, I now have 3 coats of L43 on the front half...   Jun 22 2010, 07:39 PM
tod914   Wow not grey enough? I'm very surprized to he...   Jun 23 2010, 08:29 AM
Pat Garvey   Wow not grey enough? I'm very surprized to h...   Jun 25 2010, 06:47 PM
Niklas   Hi! Why are you not using powdercoating ? In ...   Jun 23 2010, 10:23 AM
Pat Garvey   Hi! Why are you not using powdercoating ? In...   Jun 25 2010, 06:41 PM
Cairo94507   Man, are we ever going to see this gas tank? Let...   Jun 25 2010, 08:41 PM
Pat Garvey   Man, are we ever going to see this gas tank? Let...   Jun 27 2010, 06:55 PM
tod914   I went through the same thing with my intake runne...   Jun 25 2010, 11:19 PM
Pat Garvey   I went through the same thing with my intake runn...   Jun 29 2010, 07:43 PM
Cairo94507   :popcorn:   Jun 28 2010, 07:14 PM
tod914   Pat I think it has too much green too it. Let me ...   Jun 29 2010, 09:38 PM
Pat Garvey   Well, I went through several days of 95-105 temps ...   Jul 9 2010, 04:49 PM
Tom_T   So why aren't those chrome wheels on Fritz? T...   Jul 9 2010, 05:06 PM
Pat Garvey   So why aren't those chrome wheels on Fritz? ...   Jul 9 2010, 06:19 PM
Tom_T   You do it & do it right, or redo it! I ...   Jul 9 2010, 09:01 PM
Pat Garvey   You do it & do it right, or redo it! I...   Jul 12 2010, 08:00 PM
Pat Garvey   Refinishing complete! Jeez! All it needs ...   Jul 13 2010, 07:43 PM
Pat Garvey   Refinishing complete! Jeez! All it needs...   Jul 14 2010, 07:49 PM
Tom_T   Well Pat - it looks great on its own, but I can de...   Jul 13 2010, 07:50 PM
Pat Garvey   Well Pat - it looks great on its own, but I can d...   Jul 14 2010, 07:41 PM
Tom_T   [quote name='Tom_T' post='1343215' date='Jul 13 2...   Jul 15 2010, 10:36 AM
Pat Garvey   [quote name='Tom_T' post='1343215' date='Jul 13 ...   Jul 16 2010, 05:46 PM
scotty b   :blink: your gas tank looks better than most peopl...   Jul 14 2010, 02:18 PM
Pat Garvey   :blink: your gas tank looks better than most peop...   Jul 14 2010, 07:32 PM
tod914   Very nice Pat. Tank appears flawless. Drop it in...   Jul 14 2010, 05:58 PM
Tom_T   Very nice Pat. Tank appears flawless. Drop it i...   Jul 14 2010, 06:16 PM
Tom_T   Pat - I just meant that in my 73 914-2.0's tan...   Jul 16 2010, 06:12 PM
Pat Garvey   Pat - I just meant that in my 73 914-2.0's ta...   Jul 16 2010, 06:31 PM
Tom_T   Thanx Pat - I've had many surprises so far - s...   Jul 16 2010, 06:36 PM
Pat Garvey   Thanx Pat - I've had many surprises so far - ...   Jul 16 2010, 07:33 PM
Tom_T   Thanx Pat - I've had many surprises so far -...   Jul 16 2010, 07:41 PM
- Lo-Fi Version Time is now: 9th June 2026 - 02:28 AM
