1.8 question about timing, yes i searched and read all the threads |
jsayre914 |
Jun 16 2010, 05:22 PM
Speed Up !!! Group: Members Posts: 3,188 Joined: 10-February 08 From: Timonium MD 21093 Member No.: 8,696 Region Association: MidAtlantic Region |
If i just did a valve adjustment on a 74 1.8l with l-jet, and i did not have a mirror handy. I set 2 cilnders to the red mark and the other 2 the po made a nice white mark at 180 degree(thanks)
now i have an adjustable timing light. What do i turn the knob to. since the red 7degree line is now 0. am i f#$% up this job or what. i am learning... one blown engine at a time (IMG:style_emoticons/default/bye1.gif) |
ClayPerrine |
Jun 17 2010, 06:39 AM
Life's been good to me so far..... Group: Admin Posts: 15,520 Joined: 11-September 03 From: Hurst, TX. Member No.: 1,143 Region Association: NineFourteenerVille |
On a 1.8L, you don't set the timing at 3500 RPM. Set it to idle at 900 RPM and set the timing to 7.5 degrees with both vacuum hoses off and plugged. I use a digital advance timing light and set it to 8 degrees because my light doesn't do anything less than 1 degree increments.
And like the nasty California Gnome said, make sure you use the Top Dead Center mark to set the timing if you are using an advance light. |
Lo-Fi Version | Time is now: 10th June 2024 - 12:31 AM |
