new pads/rotors, now car pulls left under braking |
mightyohm |
Jun 18 2010, 04:44 PM
Advanced Member Group: Benefactors Posts: 2,277 Joined: 16-January 03 From: Seattle, WA Member No.: 162 Region Association: Pacific Northwest |
1972 car with S (aluminum) front calipers on 911T struts.
Installed new pads and rotors on the front to solve a steering vibration under hard braking (warped rotors). Had to remove the calipers to do this since the hard lines don't just unclip from the struts on this car. Now when I stomp on the brakes, the car pulls left, enough that I need to correct for it or I make an unintended lane change. Most obvious on the highway, not really noticable on the city streets, except that the front left wheel locks first if I panic stop. Bled brakes, no improvement. Also tried trading brake pads between the front calipers in case I somehow glazed or improperly broke in one side - no effect. Other work done at the same time - pulled the top of the struts out from under the wheel well to tighten the big nut that holds the shock insert on. One was loose. Drove car after I did that and didn't notice any change in handling or brake performance. Could I have damaged the brake lines somehow when I tightened the nuts on the shock inserts? Or is it more likely that one caliper is acting up for some reason? Maybe pushing the pistons back into the caliper has caused one to get stuck?? Going to try replacing the brake lines tomorrow, if that doesn't fix it I'm not sure what to try next short of tearing open the calipers. (IMG:style_emoticons/default/sad.gif) |
SirAndy |
Jun 18 2010, 05:27 PM
Resident German Group: Admin Posts: 41,681 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Maybe pushing the pistons back into the caliper has caused one to get stuck?? Sounds like a sticky piston. I did check them for movement and they seemed to move freely. I doubt that moving them would have caused this in the first place. I also don't recall one being harder to move than the others ... When was the last time they were checked/rebuild? (IMG:style_emoticons/default/idea.gif) Andy |
Lo-Fi Version | Time is now: 11th June 2024 - 01:43 AM |
