New Shock Replacement, what about Ball Joints?? |
ldino21 |
Mar 11 2004, 04:08 PM
Member Group: Members Posts: 62 Joined: 18-February 03 From: Fresno, CA Member No.: 316 |
I am getting ready to replace my stock shocks with Koni Yellow adjustable shocks all around, do most of you find it necessary to also replace the Front Ball joints at the same time?? Is there anything else I should consider repairing or replacing while I am doing this.
Also, I auto-crossed my 73-1.7 this weekend and on the first run my stock stabilizer bar broke off at the U-Tab bracket on the A-Arm. I am going to replace the Stabilizer bar with a 22mm Weltmeister Anti-Sway Bar in its place. Do you guys find it better to just weld the stock U-Tab back on, or should I just grind them off and put the bolt on tabs supplied by Welteister. Any suggestions please..... Lou |
thesey914 |
Mar 11 2004, 07:55 PM
Senior Member Group: Benefactors Posts: 1,155 Joined: 1-January 03 From: Staffordshire -England Member No.: 66 |
The ball joint usually is fubar by the time you actually remove it. I've never managed to get one off without destroying the rubber boot and since there is no replacement boot it means new ball joint. Shame really as the ball joint is a major PITA to remove from the A arm!
Brad wrote once that he removes the ball joints every time without damage by jacking up the hub and using the torsion bar to help with the separation.....tried this only last night and despite repeated twatting with a BFH on the A arm plenty of heat (IMG:style_emoticons/default/blowtorch.gif) and WD40 no joy. I had to use the fork type ball joint splitter which is what wrecks the rubber seal. |
Lo-Fi Version | Time is now: 17th June 2024 - 10:50 AM |
