New Shock Replacement, what about Ball Joints?? |
ldino21 |
Mar 11 2004, 04:08 PM
Member Group: Members Posts: 62 Joined: 18-February 03 From: Fresno, CA Member No.: 316 |
I am getting ready to replace my stock shocks with Koni Yellow adjustable shocks all around, do most of you find it necessary to also replace the Front Ball joints at the same time?? Is there anything else I should consider repairing or replacing while I am doing this.
Also, I auto-crossed my 73-1.7 this weekend and on the first run my stock stabilizer bar broke off at the U-Tab bracket on the A-Arm. I am going to replace the Stabilizer bar with a 22mm Weltmeister Anti-Sway Bar in its place. Do you guys find it better to just weld the stock U-Tab back on, or should I just grind them off and put the bolt on tabs supplied by Welteister. Any suggestions please..... Lou |
Brad Roberts |
Mar 11 2004, 07:58 PM
914 Freak! Group: Members Posts: 19,148 Joined: 23-December 02 Member No.: 8 Region Association: None |
Yep. Just did this again less than 4 days ago using the torsion bars to help put tension on the ball joint.
Oh.. Lou.. weld them on. B |
Lo-Fi Version | Time is now: 10th June 2024 - 04:14 AM |
